castleofargh
Sound Science Forum Moderator
- Jul 2, 2011
of course ABX is very limited, if only by the fact that it relies on a guy, and that it serves only one purpose. just like measurements are strictly restricted to the thing measured. TBH I really care for ABX mostly as a personal tool. my point was about people saying they can tell differences better when listening to music with a device for an hour or 2, instead of doing it with a switch and matched levels. I've heard that many times, to be able to relax, get in the mood, take in the music as a whole instead of just a fraction of sound... all seemingly good reasons that at one point I also believed in. except that in practice it doesn't work.
the ability to use a switch or an abx software have opened my "eyes" about how many biases I could fall prey to, even though I was so very wary of them. being aware of the problem never helped me, only removing the bias did. and abx for what it does, is a great way to remove some.
back to measurements, I have to agree that looking at one or 2 measurements is not enough to tell much about how good an equipment is. but by multiplying the measurements, we do end up with a fairly good idea.
frequency response alone might not tell everything about how warm something will sound, but if we also have the impedance of both the source and the load, we now usually get a way to estimate the results. given that there will be no major distortions into said load at average listening voltage. so now we need a little more. and with distortion, if they're really high, a reading of odd and even ones can usually predict if it will be subjectively pleasant, or if it may feel lush or dry. and there is no real limit to how much we can gather about a product if many measurements are available.
from my point of view what makes measurements so useless in audio is that we don't have enough, and not enough mandatory ones with mandatory ways to take them. so many manufacturers don't even bother to tell how the measurement was done(when they bother to give some at all). or they don't use the proper way to express the measurement. I suspect that it helps them leaving a blur like that, in case people contest the readings later on that it was A weighed, or into another load, or not up to 20khz... legal escape routes of sorts as a protection against badly done quality control.
many manufacturers really don't make it easy for people to use what they provide.
anyway my experience with the few devices where I could find most of the measurements I was looking for is as such:
I sometimes listened to something I suspected of being real bad(from measurements) that actually sounded nice. extremely rare, but it happened.
on the other hand, I don't remember any product with a lot of measurements telling me I would like it, or that it would be transparent, that ended up sounding bad. so to me measurements do tell a great deal, as long as we get enough and the numbers aren't fake.
about method of adjustment, it's another good stuff with its own limitations. I'm very much for any kind of controlled method allowing to get the most reliable results. it's uncontrolled stuff leading to claims that I'm starting to become allergic to in audio ^_^.
for sound having a few sliders to set volume levels, or frequency response or other parameters, needs some practice, probably more than abx. I'm thinking about how making a sound louder and then go back down doesn't put us back to the same perceived sound we had when we started. like listening to a flat sound(at least to us), if we add a few db in bass and then remove them, we will tend to feel like we're lacking in bass, or that the soundstage has collapsed a bit. and we need a little time to go back to our initial perception of the flat response. so I would suspect more failure for people doing that alone at home, and that's probably why people are mostly so bad at using EQ.
I can't imagine the hell it must be sometimes to make sure all biases have been removed when testing on people.
anyway, thanks for the interesting post.
