xaddictionx
- Jan 18, 2013
Just wanted to add my 2 cents regarding the UM Pro 50 which I got last week. I've auditioned it against the UM Pro 30, W40, Shure SE 846, etc.
I'm upgrading from Shure SE310 with custom earmolds made from impressions...
At first I was likewise a bit "underwhelmed" after hearing the UM Pro 50 right after the UM Pro 30. Turned out that the UM Pro 30 had been in the shop for several months already. On the other hand the UM Pro 50 had just arrived and only been in the shop for a couple of days been demo'ed probably a dozen times for several minutes at most... not nearly enough "burnt-in" or run in.
I went back a week later and tried again and I already could hear an improvement over previous audition. So I took the plunge, convinced that the UM Pro 50 would be less fatiguing in the long run. The UM Pro 30 isn't a bad sound at all but I preferred the less "in your head" sound of the UM Pro 50, a wider sound stage, better controlled bass and less fatiguing highs, especially apparent with string instruments and muted trumpets for example. Would have gladly walked out the shop with the Um Pro 30 but I knew that I would then wanted to upgrade to the UM Pro 50 anyway...
I've now been playing music almost continuously day and night by either listening from my smartphone on the go, in my studio at work and at home overnight by connecting to my AV receiver playing internet radio. Just for the sake of running them in as fast as possible.
I can say that there is a much more open sound already and that the treble previously being a bit congested is becoming more apparent, more pronounced but without being harsch at all. Very well controlled highs and lows, amazing lows actually, without being booming at all... You should also try using different tips, the new star tips fit amazingly well but some may prefer other tips like the foam ones...
In other words and your milage may vary but from my experience (I build high end speakers), electronics and even cables always need a bit of time to run in and open up.
Give the UM Pro 50 some time to settle and run in and go back for an audition...
Hoping to have a trial run with it again. Really wanted to get a Westone as my next upgrade. The W4R that I had was simply amazing.
