Hi, long time lurker, had the W4's for a month or two now, gonna try to be helpful for once...
what are the best non-foam tips for the westone 4s? I get a good fit now but If i can pay any amount of money to get a better sound i will..
getting more bass if its possible would be nice,
Have you tried the biflanges included with the Earsonics SM3? They apparently also sell them separately as accessories on their website, don't exactly remember the cost (I stole a couple of them from my friend who had extras from his SM3's). They fit onto the W4 just fine, and give a really balanced sound, probably even more so than the Olives. You could also try the Sony Hybrids, there was a mod that involved cutting off the stems from the stock tips to fit the Hybrids. I think there's some pics somewhere in this thread, too scared to mutilate my own tips when the Olives and biflanges fit me just fine. But like what HeadphoneAddict said earlier, custom tips are probably the best way to go if you want the best fit. (
Edit: forgot about Sensorcom tips, looks painful, but people report good fit and sound, bit pricey)
As for the others who had a problem with the highs, again, its probably the tips. But if all of them give you the same issue, try not to put the tips as far as you can down the stems, 3/4 or 2/3 's all the way down should allow the nozzle to reach further into your ears and give a better seal. I also felt that the highs became a bit softer, probably because the sound has to travel a further distance in due to the extra spacing.
Oh, I also want to ask any UM56 owners around here, whether the vinyl or silicone would be a better bet. Should the different materials impact the sound in any way? Which ones would be more comfortable?
