SoundFreaq
- Apr 8, 2005
I've tried EQUALIZER, but I like EQu best. The interface is much better and it has less bugs.
Thanks. Can you give me your settings that you entered for the app so I can try it out. Did it improve the base ? I tried the built in iPhone eq and it's crap
Cheers
In my book the Final Audios are excellent in conveying emotion, that's why I love them. The problem is, their cheaper ones, the FI-BA-A1 and SC (SB are colored and not recommended) are technically half a step below the W4, and their flagship, the FI-BA-SS is wickedly expensive. Apart from the FADs the SM3 come to mind. I ultimately failed to warm up to their overly rich mids and "surround" soundstaging, but they were very good at conveying emotion.
Edit: Almost forgot the PFE232. Highly recommended if emotion is high on your priority list. Sadly also quite expensive.
How do the FI-BA-SS and PFE232 compare to the W4 in the lower end (sub-bass impact/decay in particular) and high end sparkle? (potentially the two areas of weakness in the W4, that I can see)
How about soundstaging + instrument separation + speed (W4s major advantage IMO).
I agree with Eric that the W4 aren't up there with the very best when it comes to transparency and believe that's due to a combination of slight warmth, slightly thick note and slightly subdued dynamics. None of these is actually bothersome on its own, but altogether they make an audible difference in transparency as compared with a phone like the e-Q7. That said, I still rate the W4 overall higher than the e-Q7.
Well, first of all let's see if we both perceive the W4 similarly, to establish a common understanding on which to base the comparison. Here's an older post of mine from this thread:
While that slight warmth and slightly subdued dynamics makes them pleasantly laid-back and unaggressive, I believe it also affects clarity, transparity and liveliness in a negative way, which would all be important to convey emotion.
Both the FI-BA-SS and PFE232 aren't anything like that. They're crystal clear and transparent (the former even ruthlessly so) and not only have significantly more high end sparkle, but also a better dynamics and liveliness. Still, it should be mentioned that both of them sound leaner than the W4, due to a slightly lighter note presentation and less warmth.
The FI-BA-SS have excellent, extended bass without artificial boost (like the W4), the PFE232 are similar with a tad more punch and emphasis on mid-bass. I actually prefer the W4's lighter and more balanced bass to the PFE232's by a very slight margin.
All of them being high-end BAs, separation and speed is top notch. The single armature FI-BA-SS is even a bit faster than the others, but seems to suffer slightly more when things get busy, so the overall outcome is about on par.
As for soundstage, both the W4 and PFE232 are very generous for closed IEMs in that regard. The FI-BA-SS are vented and that adds ambience and openness to the presentation, which makes them sound even more spatious to my ears, albeit at the cost of some isolation.
Overall, while I consider both phones clearly superior to the W4 in conveying emotion, I can't really recommend the FI-BA-SS unless you're absolutely aware of what you're in for. They have a rawness and ruthlessness that's unlike any other IEMs I've heard (including customs) and are certainly not everybody's cup of tea. The PFE232 are better behaved and almost equally clear and transparent. Plus, considering they offer detachable cables with included optional iPhone remote at less than half the price of the FI-BA-SS, they're ultimately also the better deal.
Spot-on assessment and I agree, in that case neither of them would fit you. Well, that leaves only one potential upgrade I could think of, the BA/DD hybrid AKG K3003. Check the thread.
For those of you that feel the W4 (though reined in from the W3) still has a mid-bass hump, what frequency and level do you place on it? For example 80-130 Hz, 1.5-2DB. ??
+12db at 20hz (rumble), +6 db at 33hz, -4 at 125hz (boom), -2 at 250hz (warmth). Those are my settings anyway. See what you hear.
Hmmm, very interesting. To me, the bass doesn't sound full enough with your setting, but when I add in more mid-bass, it just sounds more bloated.
What EQ program is that? With EQu on iPhone, I can only EQ down to 33, so I can't hit that low rumble.
