gerG
Whoa, I figured this one would sink and die quick. Thanks for the encouragement, guys.
Uncledan, I used Canare Star Quad cable (L-4E6S). Same stuff I used in the Barney cables. Very pliable, rugged, and great electrical properties. It is pro grade mic cable, intended for stage use. That means proof against everything from high heels to hiking boots!
elnero, yes, I have experimented with the stuffing. Keep in mind that the dimensions inside headphones are 1/10th that of speakers, or less. The absorptive materials affect frequencies 10 times that (and higher) of speakers. Bass response is even more complicated because we are dealing with 2 cavities instead of 1, and your ear is inside one of them. Nevertheless, I am learning what to change to make to impact bass response and soundstage. I will post findings when I get a handle on it.
The phatpad mod can be found here:
Phatpad
jpelg, very timely question. I am trying to get the interface kit so that I can run digital output from a transport straight into the 8024. Output will go into the Max. If it sounds good, it will become my "transportable" system. My immovable system has the dbx driverack eq at it's heart, and feeds the SAC via a fully balanced cable. I love pro gear.
radrd, any cable would work, but it may not meet my mechanical requirements. I think that the Outlaw cable is divine, but unacceptable for can-cord.
Ian, if you cut into K-1000 and change the cable I will be in awe (or shock, depending on how it turns out). That is not an easy mod (I have already peeked in there).
d-ej915, it is not photogenic, but it is a pleasure to use. Neutrik hardware is strictly pro grade, and it works brilliantly.
minya, my thanks again for providing the "volunteer" for my mad experiments. As I mentioned, I am not crazy about the sound. The AT voicing grates on my ears (especially the W2002). The surprising exception has been the A1000. This is not a problem, because they will sound nothing like stock by the time I get done with them. Either that or I will get bored with the experiments and just equalize them.
markl, I named the cable above. Markertek carries it, and the cost is about $0.35 per foot. Other cables will work, but I put a high priority on flexibility. The leader sections that attach to the cups are almost as flexible as stock HD600 cable. This is a problem area with most aftermarket cables. These are like putting on well broken in blue jeans. The only problem is that the big diameter to the cups gives a bit of a stethoscope look. As always, I just stay away from mirrors.
As a general comment, this turned out to be a more advanced modification than I had anticipated. I can share some tricks if anyone wants to try it, but you need to be good with tools (you might notice dental tools in a couple of the pictures).
As for sound, night and day difference. Stock cable = no sound. Steth cable = sound. Further improvements will be minor in comparison
gerG
Phatpad
gerG
