Shawn71
- Aug 18, 2013
Airlight Thx for posting the pictures upon request... Im loving it whenever I look at them....just like you love its sound whenever you listen to them....
Had my GR07CE for nearly two weeks now, which means they've outlasted the VSD1S (right driver actually died, not a cable issue) that I had prior. Not impressed with VSonic quality at all, clearly I'm a slow learner to have bought another pair.
The VSD1S had more bass quantity while matching the GR07 for tightness in my opinion. I assumed being happy with the quantity on the VSD1S that I'd be happy with the CE instead of BE, but in hindsight I should have probably grabbed the BE. I'm using hybrid-copy tips which seem to work better than the stock items.
The good news is that the sibilance died down within 24h or so of usage, leaving an accurate treble and midrange. Electric guitars sound amazing. Separation is pretty good and the sound signature is fairly neutral. Soundstage has very good width for an IEM as most reviews state. I have EQ'd in more bass but it's a fine line between quantity and accuracy/muddiness when doing that, seems to work well for some albums and not for others.
Hopefully the GR drivers will last longer than the VS.
Right driver went out on your VSD1's? Interesting. On my pair of GR07CE that recently just happened to, and I sent them out for repair. Though you are the second occurrence I have seen, or heared, with a driver outtage. Hopefully just a coincidence.
I think the GR07s feel quite solid. They do lack a good strain relief on both the earphone and plug end, the cable goes into hard plastic essentially. The plug is angled though so it's generally easy to not have ot pointing into pockets or such.
And I use the included earguides when wearing them, which means that any tension in the cable is generally dissipated by the earguide over your ear, it never feels like the cable is tugging on the actual driver or housing.
That really sucks to hear. I think this problem is more common than is made public, although the GR07 seems to fare better than the VS lineup for some reason. I was told by LMUE that plenty of VSD3 have already been returned for driver failures, along with the previous D1 series. They said that the GRs were better, but who knows what that means.
How long did you use your CEs? If mine drop a driver without lasting at least 4-6 months, they will be the last VSonic item I purchase. If they last over 6 months I suppose I can deal with replacing at that interval.
I did notice that both the VS and GR items don't use a strain dissipation in form of a knot tied in the cables inside the housing before being soldered. They rely on the glue bond between the cable and rubber grommet to transfer loading. I'm not sure if that could possibly be a contributor to failure, but it basically means that after any glue melts (body heat etc), the cables can actually pull on the back of the driver.
I'd be interested in opinions on whether this could be the cause of premature driver failure. I have seen a few pictures where the driver has separated.
I read the whole thread and others, I find the GR07 CE very interesting, but can't risk any durability issues... Have they improved or is it a higher than the norm risk?
Thought I should update, after a week of break-in, the bass opened right up and is as good if not better than the VSD1S - tight and accurate. I've had to change my EQ setting from when I first got them from aggressive bass to just a moderate increase. Seems like the CE was indeed the right choice, no desire for the BE now.
It's a shame about the longevity issues as these are quite fantastic for the price.
Thanks, yes it's a shame, returning them for the warranty would be a huge hassle for me.
