attmci
All 421A has bottom getters, and clear-top. If you can find some 5998 like those, grab it.The tube has no date code on the base or on the glass (maybe it was deleted?). All I can see is:
Besides that only TUNG SOL / Made in USA. It came in generic boxes, so no information on them either.
A similar construction I've found here, on a tube labeled as Tung Sol 421A:
https://www.ukaudiomart.com/details/649372022-tungsol-421a5998-power-tubevalve/images/1612914/
However, soundwise, the tube sounds to me similar to a 5998, and not as WE 421A (yep, I own both and I hear clearly differences between them). So it is a tube sounding as 5998, labeled sometimes as Tung Sol 421A and it has top and side O-getter. But regarding the sound I would need more time since I only had a few hours on them.
Because it is different than everything I've seen I try to find out its story.
For manufacture date, does the 322xxxx ring a bell?
