The real difference between the two in use is the battery life which for the VE is almost triple that of the P10. So while the P10 is charging you will be able to continue listening to the VE without any problem, which in addition to this, is complementary to the PA10 being much more transparent and less colourful.Was waiting for your impression vs PA10 as I have been planning to get RA2BFE. The PA10 will get more refined and open after or around 50 hours. It just becomes more effortless if that makes sense. So, keep an eye for that.
But I am still planning to get the VE because the PA10's 4.4 input does not output to 3.5mm and I have a lot of 3.5mm non detachable gears that I enjoy.
Edit: Another reason is that, I feel the VE Prime DAC will be a perfect partner for PA10 with its 4v balanced line out.
Venture Electronics RA2BFE Impressions and discussion.
- Thread starter Polky74
