Wood
- Oct 20, 2009
You will need to add the larger decoupling caps. Best to remove the 10uf large SMD tants and put them there.
Those caps are ok, but you can get away with anything 2.2uf (smaller size is useful here) and above. MKP is usually preferred to MKT, but they are both good, try Bennic, Mundorf m-cap that kind of thing, some people have used Dueland!! Yes they are located at the top of the floating board.
