- Sep 3, 2006
That board is powered through the USB port. That means your phone will need to supply the power out the USB port, and the OTG cable you select will need to also be capable of transferring the power.
I wonder how much power it takes to illuminate a toslink optical port? It will be interesting to see how well a $15 device works. If Apple were to certify a 3rd party vendor for something like this it would be $200. Good Luck!! Its too bad cell phone makers don't put toslink optical output ports inside the 1/8" headphone jack like a lot of the old portable CD players used to have.
If it is done properly, there should be no data loss. If it is done improperly, you could have data loss and also clock timing issues. I have no idea what will happen with that board.
I use one of those to power an external drive off two USB ports. I would think it would power your optical board as well as charge your cell phone. Never tried it this way though
