kramer5150
- Sep 20, 2004
The problem is that to use the internal DAC of the Marantz, you need to feed it a digital signal.
My concern is that most USB -> S/PDIF (TOSLINK or Coax) converters are USB powered, like this one:
http://www.amazon.com/USB-DAC-PCM2704-Optical-Converter/dp/B0093KZTEA
and this:
http://www.amazon.com/gp/product/B00A2QJK5
and this:
http://www.amazon.com/Turtle-Beach-Advantage-Digital-Adapter/dp/B0036VO4X4
and this:
http://www.amazon.com/Ha-Info-U2-SPDIF-Converter-TE7022L/dp/B006WU7E92
and this:
http://www.amazon.com/Peachtree-Audio-T1-24-96/dp/B00AEN0SIW
and this:
http://www.amazon.com/PHIREE-U2S-Converter-upgrade-version/dp/B00OMPAOO6
That would be fine for a PC, but not for a phone.
It would be much easier to have a device that obtained it's power from it's own A/C power supply. That's why I suggested the Audinst HUD mx-1. It has S/PDIF output AND it can be powered externally.
HOWEVER, if you are going to buy a device like the Audinst HUD mx-1, then why not just use the DAC in the mx-1 (or the Modi)? There's really no benefit to the Marantz DAC over a good USB DAC. If your Marantz had the ability to accept the USB OTG directly, then the answer would be much different.
If you can find a USB->S/PDIF converter that is externally powered AND cheaper than a readily available externally powered USB DAC, fine - go for it!
x2... the confusion here is PC USB is NOT universally compatible with Android / cell phone USB.
OP, youre definitely going to want a device thats powered externally. You would not want a device that tries to draw power over USB from your cell phone.
