UAPP 2.1.5 now supports UPnP/DLNA. There are some quirks though, like not remembering which server/folder you selected last, but it should at least perform better than SMB.
Wow that's really great news, thanks a lot. Keep up the great work!
does it work properly nowI can only get one track at a time, then UAPP moves to the next internet radio in the list. When track is loaded it runs very smooth.
When there are glitches I think it is a streaming issue not UAPP.
The lastest lollipop update for the Xperia Z1 seems to have broken the USB Audio support.
^ Grrr... they removed the USB Audio support with the lollipop updated on the xperia z2 as well. Would installing UAPP not work though? Isn't that what the app does (allows your phone's USB port to output audio)? I don't want to downgrade back to kitkat!
Tidal now works on UAPP.
In Bubble uPnP access Tidal. Save your album into a Bubble playlist. Play Bubble playlist from UAPP
Qobuz in Bubble UPNP works with this method too!!! Save the album into a Bubble playist. Play Bubble playlist from UAPP. Nice!!!!
