Biesas
- Jan 8, 2011
Well I used sort of a guide which was posted on this thread about a good 150 pages ago
if you are interested I can send you that by PM. The guide was written by benzoylmethyl. You have to sacrifice one pair of the PRO900 pads but believe me its worth it, especially since you get 2 sets of pads with your PRO's
you got to take of the XB700 hundred pads, cut of the velour pads of the retention ring on the PRO900 leaving the mesh intact and then you got to glue the XB700 pads onto the retention ring using some sort of strong glue. I personally used super glue, just make sure you get it right! The pads go on the headphone like a charm and they are very comfortable compared to velour pads and isolate a lot better and leak a lot less!
Did you have to do any modding to the XB700 pads like gluing them onto your PRO 900s?? Or did they fit nicely over the 900s??
I'm going to get myself a pair of the PRO 900s soon and want to upgrade them with those nice, soft, cushiony XB 700 pads
