Originally Posted by Berlioz /img/forum/go_quote.gif
Dark, dull, AND muddy eh? Well what Denon headphones are you using (Please don't tell me you already mentioned this!)?
I didn't. I'm using the Denon AH-D2000s. They have been MarkL modded and since then I've gone further by recabling with the Mogami W2534 and further still by adding a tiny bit of padding to the insides to further reduce and control the bass. I would definitely describe these headphones as a bit bright. Some artists and tracks can get a bit sibilant at times (especially with some oversampling DACs such as the one in my iBasso D3) though the Mogami cable (and surprisingly the padding) helps a bit.
Comparing earphones to headphones is not really a fair comparison IMHO. Your Denons may just be THAT much better. |
I 100% agree with this. I don't mean it to be a fair comparison either, just that they feel far too dark now that I'm used to my Denons. Though I perhaps don't mean to compare, it's rather hard not to. I may need to try to better match them somewhat perhaps. The main problem is a bit of a monetary issue... Well, I don't need them to be as good or better, but it's a bit annoying at times. In the meantime I think I'll dig out my old Shure E2Cs. They were a bit better at this much. I don't particularly love their sound (I've found a few things where they can make some things -- such as even someone's voice -- sound kind of unnatural), but every since I found Comply foams at least they no longer sound flat and weak due to a bad seal (I never could get ANY of the stock pads to fit my ears as well as they should have.) They definitely aren't bad, I'll give them that much, but I bought the UEs looking for something better, lol. Also, even with the Complys they hurt (as in the way they go in my ears) but I usually only need them for a little bit at a time anyway.
I suspect that ever finding IEMs that sound as natural and as detailed as these Denons would either be next to impossible or so far beyond my budget that it doesn't matter. Well, that's ok. IEMs are just for on the go to me. Still, they shouldn't sound THAT much worse, lol.
You might want to find someone else who has the same earphones and do a comparison. |
Sadly, I'm the closest thing to an audiophile of all the people I know. The closest person I've spoken to more than a few times uses BOSE headphones even. There's nothing to compare to.
Sorry for not reading through your last post more thoroughly. |
It's ok, I got a bit of a laugh at that one. d-:
EDIT: After visiting their site to look at the user guide and watching the video, I realized I wasn't putting them in right. Most IEMs go right in the ear canal. In the worst case, those Shures had to be practically shoved in so deep that an onlooker might not even see them in your ears from most angles. These, by comparison, have to be put in very very loosely. Almost on the edge of falling out even. They still sound dark and synthetic compared to the modified Denons, but at least it's not quite so bad. Of course, this means I do have to rely on that "memory wire" to help hold them in place and I'm not sure how to do that and still fit them in that little metal box that came with them to carry them around without that wire bending every time. (But they don't fit in the Shure case any better.)
