chesebert
18 Years An Extra-Hardcore Head-Fi'er
- May 17, 2004
I thought this is common knowledge and is a concept well-known among headfi members
Originally Posted by OverlordXenu /img/forum/go_quote.gif As long as the transport outputs bit perfect audio and does not resample, it will sound the same as any other transport that does the same. |
Originally Posted by Herandu /img/forum/go_quote.gif All true and well, but the problems can start before the transport output. A dodgy laser will send dodgy data to the optical to digital converter. And the rest,as they say, is a stream of 1's and 0's. But how accurate is the bitstream? A good set of test discs is the Philips ones with the fingerprint marks and drilled out holes. Yes, drilled out holes! You and me know that if there is a hole in the CD, there can't be any 1's and 0's. Go tell that to the test CD, because it WILL produce an audio output. So,is that a reliable transport or not? |
Originally Posted by OverlordXenu /img/forum/go_quote.gif Does bit-perfect not mean the same bits as on the original media? |
Originally Posted by luidge /img/forum/go_quote.gif Well i don't agree with you Lazarus! I know upgrade my transport to a Cambridge CD6 and the toshiba was let behind in the dust! Such a glorious sound with his digital out i'm crazy about it. I now use a Lavry DA10 too, but i couldn't try it with my amp yet (need to wait for the adapters) but from the headphones out of the DA10 the music is rich and soooooo detailed. So yes i also think that the DAC part is important but dont neglect the transport my friend |
Originally Posted by OverlordXenu /img/forum/go_quote.gif As long as the transport outputs bit perfect audio and does not resample, it will sound the same as any other transport that does the same. Why? Because bits are bits. 101010101 will sound the same as 101010101 no matter the transport used, it will stay 101010101. |
Originally Posted by sejarzo /img/forum/go_quote.gif Herandu, let's just consider typical CD audio transports then and not PC drives.....how often does error correction kick in on a clean disc with a good transport? |
