- Feb 1, 2011
They don't have polarity so it doesn't matter which way you plug them in
I am using O2/ ODAC with my LCD2.2 + Q cables.
I was happy with the sound, lean and fast.
Until I received my UM Merlin, then I thought that with it was a little too lean.
Switched back to the stock cables, it was better, but then, the veil is back.
So, I'd like to give other cables a try.
Copper ones of course.
The spec of the Black Widow is pretty similar to Q cables.
Litz, 20+ gauge.
Perhaps I should to try the Scorpion.
What is the difference in sound quality between the 18 vs 24 gauge?
Frank has also suggested the Copper Venom - I would assume that this is out of my budget, anyone using this cable?
I agree as well. The O2 is a very capable amp.O2 is not low end in performance, neither is ODAC, both are audibly transparent and quite a few people use LCD2 with them, they have plenty of power for that use.
Just because you personally prefer a bigger more coloured amp, his is not inferior. The O2 can handle the LCD2 and at least your hearing the sound of the headphones with it, not the sound of the amp.
Go with a nice copper cable, should warm the sound up a bit
No offence to anyone either, just my $0.02
Best systems I've heard so far are HE-6 with Icon HP8 MKII with upgrades, and I enjoyed the beyerdynamic T1 with the O2 more than T1 with HP8 or beyer A1 amp.
No offense but none of those is exactly cutting edge and to be honest I am quite puzzled what sense the HE-6 makes on the Icon, unless those upgrades are really something. The HE-6s require at least 5Watts of juice to sound right.
Low setting - 451mW at 32 ohm, 720mW at 50 ohm, 667mW at 150 ohm
Mid setting - 735mW and 10.5Vrms at 150 ohm, 653mW and 14Vrms at 300 ohm
High setting - 403mW and 11Vrms at 300 ohm, 482mW and 17Vrms at 600 ohm
I would recommend the original poster to run the LCD-2s in a system the sounds properly, and the key here is system, and then he will have an easier decision to what cables he needs. Just honest advice really. I mean he's going to wait a few weeks, right? But Frank's cables are a great improvement to stock either way.
Very nice. Heard only good things about BC.
Sounds like you should avoid Silver and get a copper cable.
Litz, 20+ gauge.
first of all..i dont wanna sound like a snob.and i dont wanna offend anyone...but ru really using a low end amp/dac like the O2 with a higher end (expensive) lcd 2? u know ur missing out with that right? IMHO
but that was not the reason why i wanted to reply on ur post...
its this:
i wanna clear something up about what u said as its not completely true:
as u probably dont know, the BW (i have my second one now) is an OCC cryo treated Litz cable (mine being 22AWG with 8 wires)...but i read on the thread that a Q Cable (from Steve) is based on ETP copper wire..to my simple knowledge that kind of wire has less purity then OCC copper wire that Frank uses...and for sure much more cheaper to be bought by the builder then for example OCC or OFC copper wires..and inferior sounding as a whole (IMHO!)...so for sure they are not similiar....only familiarity would be that they both are copper based and have somewhat same AWG....
just wanted to make that clear...as i dont like misunderstandings...
once again..my apologies if i sound to direct or a bit offensive...i am just trying to be honest.
