Yes. You can use it while charging. And no, there isnt a bypass function.Hi everyone. I plan to buy a NX7 to feed my upcoming high impedance earbuds. I was wondering, can i use the NX7 while charging? Does it have a bypass feature so it can preserve the battery health? Thank you
Topping NX7 Portable Headphone Amplifier
What is/are the most power hungry headphones you guys are able to drive flawlessly with the NX7?
What headphones would you be trying to drive?What is/are the most power hungry headphones you guys are able to drive flawlessly with the NX7?
Main attractive point to me in nx7 is portable single-ended clean power. Great partner for headphones that are wired single-ended and cannot accept balanced signal such as beyerdynamics and jvc sz2k. Meanwhile most other portable amps are focused on balanced power and their single-ended outputs are poopy.
Nice OPA1612 in there... I guess that accounts for the soundHas your battery gone bad?
Seems like taking PCB out is not simple. Besides Topping propaganda, I've only seen one picture of NX7 pcb posted online, here. You could attempt to message the user who posted it there, they might be able to help you out.
This post says it's OPA1612 (1pc) + BUF634A (4pcs) powered up by TPS65131. Wondering how Topping proprietary NFCA module plays a part in this?Nice OPA1612 in there... I guess that accounts for the sound
No idea, I've no idea how it works. Probably before it hits the OPA.This post says it's OPA1612 (1pc) + BUF634A (4pcs) powered up by TPS65131. Wondering how Topping proprietary NFCA module plays a part in this?
BobSmith8901
- May 5, 2015
The thing I like about Topping is that you always feel like you're getting the power that they state in their specs, and then some. Obviously the NX7 is a 1.4W beast but even my NX4 DSD at 293mW on Hi Gain gives the impression of power to spare. Both have very clean sound.No idea, I've no idea how it works. Probably before it hits the OPA.
Yeah. I'm running a DT 880 600 ohm's on the Topping A30 pro, and I barely ever turn the knob past 10. Fully driven.The thing I like about Topping is that you always feel like you're getting the power that they state in their specs, and then some. Obviously the NX7 is a 1.4W beast but even my NX4 DSD at 293mW on Hi Gain gives the impression of power to spare. Both have very clean sound.
Knee Deep In Epoxy
Wondering what DACs people here are using the NX7 with?
I have tried it with the Cayin RU6, RU7, Questyle M15, iBasso DC03 Pro, Dethonray Honey H1 and Mojo2. All, except the Mojo2, work flawlessly on their maximum output with the NX7. The Mojo2 is very distorted when used at its max. it clears up when I reduce the its volume/output by steps.
Does anyone else here use the NX7 with the Mojo2. If so how do you set up the Mojo2 in the pairing?
Sounds like you're getting clipping due to pushing too much vrms from mojo2 into nx7. The other dacs you've mentioned are much less powerful through their single-ended outputs than mojo2. I think nx7 supports 2.5vrms input max. I have both devices but to be honest I haven't tried stacking them together yet. Based on my experience in similar situations with other devices, I'd put nx7 volume knob around 12oclock (at desired gain setting) and control volume through mojo2, basically using mojo2 as a pre-amp volume control. This way you should be able to find optimal output level from mojo2 that doesn't distort/clip. I'd also suggest in mojo2 thread which is much more popular and various users have reported on using mojo2 with external amps.Wondering what DACs people here are using the NX7 with?
Knee Deep In Epoxy
I was looking for the NX7 input power but wasn't able to find it. That was the missing piece of the puzzle.Sounds like you're getting clipping due to pushing too much vrms from mojo2 into nx7. The other dacs you've mentioned are much less powerful through their single-ended outputs than mojo2. I think nx7 supports 2.5vrms input max. I have both devices but to be honest I haven't tried stacking them together yet. Based on my experience in similar situations with other devices, I'd put nx7 volume knob around 12oclock (at desired gain setting) and control volume through mojo2, basically using mojo2 as a pre-amp volume control. This way you should be able to find optimal output level from mojo2 that doesn't distort/clip. I'd also suggest in mojo2 thread which is much more popular and various users have reported on using mojo2 with external amps.
Someone shared this great chart with me in the mojo2 thread so I can know what the output power is at different volume setting.
With those two pieces of info I should be sorted.
Thanks!
Did you get it to work without distortion? Do you like mojo2+nx7 stack better than mojo2 alone?I was looking for the NX7 input power but wasn't able to find it. That was the missing piece of the puzzle.
Thanks!
Knee Deep In Epoxy
Yes I got it going without distortion - thanks. I need to give it more listening time to time to determine how I feel about the sound.
The convenience of having a 4.4. output is great as I like to minimise cable swapping.
My first impression of the sound is that it sounds more organic and with better decay through the mojo2 directly, but will give it more time.
vandung2510
How long is the usual using time of the NX7 from full battery to depleted for you guys?
Nx7 is rated to last 20hrs on low/mid gain, 10hrs on high gain. I'd say in reality that's close to accurate, maybe about 10% less.How long is the usual using time of the NX7 from full battery to depleted for you guys?
