DaveBSC
- Dec 31, 2009
Thanks for the recommendations, very helpful. I think I actually may just DIY the cables at this rate. Looked at the prices and saw that the actual cables for even $200-600 cables are being sold from the manufacturer for about $0.93/ft.
Is there a good place to read about the kinds of cables/wire available, and the best connectors/terminators to pair them with? Is there a good thread I can read for the equipment I need to make a proper cable? I have a lot of shop equipment on-hand, so if it's standard stuff, I probably have it all already. The Oyaide and Furutek bulk wire suggestions look very attractive.
The main thing I'm struggling with is that I'm going to have a cv transformer located 20ft or so away, so I need to figure out the best way to manage that distance in between. I was thinking of having a good quality splitter run directly from the transformer, then use 1.5-2m cables to connect from the splitter to the amp, D/A, etc. One thing I'm not sure about is if I need a fantastic cable for that 15-20 feet of distance between transformer and splitter, and if all the cables need to be the same, like if I had to stick with the Furutech or Oyaide throughout. Qty2 4.5m cables and qty1 7m cable would probably run close to $700 for the wires alone for the Oyaide, and that doesn't count the connectors.
The Cable Co and Parts Connexion both have good selections of bulk wire. VH Audio also sells their own stuff in bulk, as well as wire from Neotech, Oyaide, Furutech, and Acrolink. Aside from bulk wire which just requires connectors and possibility a bit of soldering, there's also hook-up wire, which is just raw insulated or uninsulated wire and comes in stranded, round or rectangular solid core, or litz. I don't really recommend working with litz wire because its a PITA, each insulated strand has to be stripped in order to terminate it.
You can just braid hook-up wire if you want and then add some plugs. That's all standard Kimber cables are. Three runs of Neotech teflon insulated 22AWG OCC solid core in a tri-braid would make for a really nice interconnect, at a total cost of about $6/ft. If you want to follow other types of spiral designs, you'll need hollow tubes to act as a support structure.
For a long power cord run, I would use a large gauge (12AWG+ per leg) with a braided metal and foil shield. Very long power cords are susceptible to EMI and RF, and you want the shielding to block that out. If your using shielded bulk AC, you connect the shield at the wall end, (via the ground terminal) and leave it open at the component end. Connecting both sides turns the shield into an antenna, which is self defeating.
Other than that, you need some glue lined heatshrink, which acts as a boot and holds the connectors and Techflex in place. If you want to work with multiple stranded conductors, I highly recommend using crimp sleeves. For power cables Marinco, Hubbell, and Wattgate plugs are all pretty similar and work equally well. The Shurter IECs are a few bucks cheaper, but a pain to work with.
