Thanks for the reply.
What would you recommend as a budget amp which will be enough to power the Creative Aurvana Live 2?
Specs are:
Impedance: 32ohms
Sensitivity: 105dB/mW
Planning to use it for desktop
I am not actually that familiar with budget desktop amp myself to make any useful recommendation (I am more into portable amp). But if you can find a desktop version of O2 (Objective2) headphone amp then you should be all set. It will cost you somewhere between $150~200 though.
