elmoe
Formerly known as JashuganHeadphoneus Supremus
How did you carry out your ABX tests?
It depends on which tests in particular. I tested power amps, headphones amps, lots of interconnects, and different files from 64kbps to DSD.
Awesome, a friend from a chilean forum, did some tests with audio formats, and found differences up to 320kbps mp3 vs FLAC 44.1khz/16bit with 7% chance of guessing. FLAC 44.1khz vs 96khz, no difference whatsoever.
But in this thread they're testing transports for DACs. There must be diferences but for one I know I would fail in double blind tests, but I still believe there are differences. I don't trust ABX boxes, I think that if more than one DAC is playing at the same time some distorción goes through.
Changes in transport - that can be argued I guess. Changes depending on your OS or CPU? Sorry, but I have to disagree.
I can tell you that I feel my craputer w foobar sounded better with Ubuntu than with Mickeysoft with it's default not-so direct sound and horrible drivers. Things got more even as one might expect when I used ASIO drivers (though they are a pain). I still have not done a test (ABX or whatevs) with ASIO vs Wasapi, but I'm predisposed in not expecting lot's of difference.
I don't think the CPU is going to have a major impact, unless it's something like an 8051. But the particular PC built might, depending on components and how well it was put together.
Whatever one may believe or not, it's good to keep an open mind and check things out whenever possible... I've learned quite a bit that way.
a more simplistic approach is win ser 2012 and audio optimizer . it elevates things to another level . even if not using batteries or linear psu,s the gain is there . so if this true then various cpu,s must be true as well . lets face it computer audio is not real until it gets to the analog output and who knows what is going on to get it there .
al
al
