THE WATERCOOLER HEADPHONE EDITION – Headphones, Amps, DACs, and desktop/home audio related – a freewheeling discussion of gear, impressions, music, and musings.
May 14, 2024 at 7:08 AM Post #316 of 1,001
Are you sure you don’t have a bad adapter ?
Out of curiosity I searched and pulled up an old post from 2009 where a guy measured signals through a variety of cable lengths with and without adapters and a the difference between a six foot length of cable and two three foot lengths with a connector joining them to a total six foot length was 0.005db. Worst case with any configuration was 0.03db which was equivalent to 0.1% difference.
I have in the past set up a test with a standard cable and the same cable plugged into a series of adapters up and down for a total of five additional connections that were easy to remove quickly for a simple A/B test and it made no obvious audible difference.
Totally saves me the trouble of having to test it out myself, thanks! :smile:
May 14, 2024 at 9:07 AM Post #317 of 1,001
Happy to be joining this thread and look forward to the endless chats. :o2smile:
Thanks to Eyal for making this!
Currently I am listening with the ZMF Aegis and Caldera Closed, and this pairing is truly something special. I can't wait for more people to discover this, and in my opinion it doesn't get any better. Zach is on fire with his latest offerings no doubt.
May 14, 2024 at 9:49 AM Post #318 of 1,001
What output tubes are you currently rolling with the Aegis?
I’ve had the Mullard EL37 for awhile and they are exquisite, airy, refined . Recently switched to Tung-Sol made RCA 6550 that have more texture and bass, and going to switch to Shu Guang WEKT88 Plus next.
May 14, 2024 at 9:56 AM Post #319 of 1,001
I am currently running a pair of Russian 6P3S from 51', and they have deep bass, linear mids, and really extended treble without being harsh. The staging is quite impressive and very expansive.
I also have some Mullard 6L6G 54' arriving today. . .
What rectifier are you running?
May 14, 2024 at 10:00 AM Post #320 of 1,001
takatsuki rules
May 14, 2024 at 10:01 AM Post #321 of 1,001
Very cool. Never tried those. Will put on my To Do list.. 🙏
May 14, 2024 at 10:52 AM Post #324 of 1,001
My jaw dropped on takatsuki after trying electro harmonic, psvane, and kr audio. My tube rolling is over. Takatsuki makes a fantastic rectifier 274b but it does tighten the sound stage with great imagery, it gets a real boost with power tubes 2a3 but many ways to slice the cake
May 14, 2024 at 11:01 AM Post #325 of 1,001
Doesn't surprise me as those other new production brands are average at best. You ever try any NOS/OS rectifiers?
May 14, 2024 at 11:15 AM Post #326 of 1,001
They are definitely worth a try.
What rectifier are you running in your Aegis?
I currently use Philips Miniwatt GZ34 (Sittard factory, 1968, black base, DD getter). Input tubes are Tung-Sol 6SU7GTY (1950-52).
Which amp are you using it with? I have yet to try this brand.
May 14, 2024 at 11:16 AM Post #327 of 1,001
No, it’s the same with other adaptors I’ve tried. 2 to be exact.
Yeah I measured resistance and capacitance both with and without the adaptor and it was negligible.
Someone told me Tyll Herstens said the adaptor adds a bit of crossfeed.
This was after I told him what I heard.
Dunno man I can’t hear the difference between different wire.
May 14, 2024 at 11:21 AM Post #328 of 1,001
Ah, okay that makes so much more sense! 🤣
I can't say that I've ever noticed that before, but then again I've never tested for that either. I don't think that I have a 3.5 mm and a 6.35 mm version of the same cable laying around... but if I find one in storage somewhere, I'll give that a listen.
Yeah I wouldn’t have heard it either if I wasn’t bored and doing a mini project making headphone cables. Lol
I never noticed it before.
But I made a few cables and after not being able to hear a diff between wire, I heard a diff between two and couldn’t figure it out except the adaptor. That’s how I stumbled upon it. So I tested using that variable.
Yeah if you get a chance it would be cool for you to test.
My 54 year old ears can hear the diff.
I do still have good hearing though. But still. Things are starting to roll off. Lol
Cheers man
May 14, 2024 at 11:33 AM Post #329 of 1,001
Nope, just the ones I mentioned
May 14, 2024 at 11:38 AM Post #330 of 1,001
Tempting! I am on the fence about throwing $1700+ on Tak 2A3s for my WA23 (leaving the rectifier alone for now), but fluctuating between tubes or upgrading power conditioner or going all out on a total DAC. The latter being most expensive obviously, but the most likely immediate boost in SQ as its an actual component upgrade.
