spurxiii
- May 18, 2013
If you're handy you should give it a go
Not sure how flexible the cat5 cable would be
Well Im thinking if I do the removable cable mod, I can run CAT5 cable to the 3.5mm socket, the rest will just be a normal 3.5mm extension lead. That way the gauge of the wire wont be an issue for mobility. BUT! Will it really make a difference or will I be wasting my time?
In this hobby you never know what difference any mod makes. Its all trial and error. Even buying a can, you're never sure if its right even after reading all the reviews. You need to listen to a can, and have it with you for a period of time. There are cans I've bought which I absolutely hated, but over time, they became one of my favourites. Then there are others which sound good at the start but over time you grow not to like them as much anymore. It's a weird hobby
If you are in luck, maybe local jaycar has digitech pro monitor headphones on sale? Comes with two pair of hm5 pads. On the website those are priced 99aud. Those guys are ripping off you locals. I can get those delivered to finland allmost half that price
That's crazy, I'm not going to spend $99 on cans just for the pads
What is crazy about that ??
It sounds very normal to me LOL
