Ray Samuels
Member of the Trade: Ray Samuels Audio
- Mar 2, 2003
I would like to introduce to all Raptor's owners the new redesigned power supply that will be offered as an upgrade for a very low price of $200.00 ONLY.
This newly designed printed circuit board houses a custom-built toroidal power transformer, constructed to our exact specs, diameter, height, current & voltage, by one of the best respected manufacturers in high-end audio, PLITRON.
The printed circuit board also houses a 3.5A regulated 12VDC switching power supply for the filament of the tubes. All caps offered in this power supply are panasonic high temp rated at 105 degrees C.
This fully functional power supply is intended to fully replace your Raptor's existing power supply.
The new power supply runs cold to the touch, with very little heat is generated internally, no starting noise is associated with it when the power switch is turned on, no more mechanical noise associated with this design, and reduced magnetic field.
This new power supply gives the Raptor a new level of outstanding performance that is up there with the best of the high end headphone amps. This upgrade includes all parts & labor.
For those who can not afford this upgrade, we can modify your existing power supply by removing your 12VDC power supply & installing the new switching power supply, the same offered in the new power supply, for only $50.00 + shipping. Your power supply will run barely warm to the touch, just like the new one, and it won't give that starting hum noise when the switch is turned on.
Thanks,
Ray Samuels
Thanks,
Ray Samuels
