goldenSHK
- May 25, 2013
A planar driver and 50mm driver? Wouldn't the result be a massive sized headphone?
Size is not a problem for me. It shouldn't be any bigger than an Audeze headphone.
tisk tisk... you know how it is around here. No video means no truth
I'm really surprised when there is talk of headphone amps in this thread that Digizoid is not mentioned too often especially now since the Digizoid FS is out.For all you bassheads who like your headphones sound but just wish they had abit more bass should check the digizoid FS out.It's the only headphone amp + EQ (Can raise bass + treble) in one that I know of
I think the best headset Bass head. It is the Beyerdynamic DT-770 Pro 80 ohms.
Much more comfortable despite the clamping force and there is a better seal around my ears.
Hey guys, I'm planning on building my own headphone that will hopefully be "the god of bass," but I need some helpful information. I am looking for the ultra-clarity that planars provide with the texturized mids and detailed (but non-piercing) treble of high end planars and also the air rumbling and massive air flow of big ass driver dynamics. The perfect endgame ideal for the insatiable basshead audiophile. Sound quality and earblasting bass. So in order to make this reality come true, I've acquired a pair of T50RPs and various 50mm drivers from different praised bassy headphones such as the Ultrasone DJ1 Pro, SigDJ, and Denon D2000. I am hoping to use some form of crossover to have the planar diaphragm of the T50RP dedicated to highs and mids while one set of the above 50mm basshead canon drivers completely dedicate themselves to low-end vibrations of my skull .I know playing around with venting and distortion will be even more difficult now that there will be 2 drivers - it's hard enough to dampen properly with just one. I'm posting here to ask if anyone has textbook style information on how the SZ2000s are implemented and also if anyone has experience building speakers or similar type of audio gear since this will literally just be small speaker system with 50mm subs that you can wear on your head. Thanks!
I immediately thought XB1000 drivers. 70mm vs 55mm... And with some good pads and a planar driver... I think that would be a winner. The SZ's subwoofer is already in a housing with metal chamber. Using the XB1000 driver, we could see what those 70mm's are really capable of.Thanks man...that's dope. Those cans slam nice. The clamping force made doing a video tough
Sounds like a difficult but ballsy idea!!
I would thing a hard metal housing would be a must as it needs to force the bass back out and not let it tone out any plastics or low resonance materials. What kind of casing/housing/cups were you gonna use on this frankenbass machine?
Sorry. The best bass Headphones is a Stax SR-007 MK1 o SR-007 MK2 modded.
In the best bass orthodinamic is Audeze LCD-X
Respect the OP's (original poster's) intentions and try and keep comments on topic. If you feel a strong need to (continue to) discuss a particular, but off-topic subject in a thread, start your own thread and direct post a link in the thread rather than derail that thread. If it's not a discussion worthy for a thread, consider taking it to private messages.
Thanks for the images of the SZ2000. I didn't know they were using a "bass ring." So is there an actual crossover circuit in this headphone like speakers or is the filtering of the frequencies non-electronic/acoustically filtered?
I was originally thinking of just machining round cups out of some aluminum magnesium mix billet (that'd make these things even heavier), but maybe I'll try plastic first. I am kind of stuck right now trying to decide if I should try to use a crossover circuit and electronically separate the two drivers completely or just wire them in phase together and just dampen out the highs and mids in the dynamic driver while letting the planar just produce the entire frequency range from bass to highs and using the jumbo dynamic driver for that massive kickup in bass. I guess I'll just try both ways and see which way sounds better.
Which fiio e12 is the one that's recommended or do they both give the bass needed? I'm asking because I have the newer one and don't really want to sell it back if the bass boost isn't the one recommended but won't have a choice. I know the first batch had sub bass boost and this one has 4.2db@100hz....I mean I like what I'm hearing either way but if the old version is the one to get, I'll have to get rid of this one.
