Yes, yes, I did your mod, and for that I cannot thank you enough
Thing is, the Cricri+ is described as bright, so it got me worried a little. But, yeah, I got a feeling that with any quality source the 8.35D will give you quality result
As for the headband, I'm still in the planning phase. Right now I'm thinking of something like
Paradox Mod, but a) given how little vertical estate I have, it won't be easy to sort out the right length for the ribbon, and b) either way I'll have to do something about the cable between the cups. I'm definitely moving it above the metal band but I want to protect it somehow, be it with some hard packing foam, or some plastic, or anything.
Then I've got this wild notion to wrap it all in leather—the cable, the metal band and the ribbon—but I don't know if I'm going to be able to make it pretty. It's a complicated design and I have zero experience with leather.
