Do the X1 will be on sale at Aliexpress someday?
Can you send me the link of your store?
Maybe I could get the X3 if its on stock
http://www.aliexpress.com/store/1473108
Hi, just a quick question: is there any way to ignore a folder when scanning media library?
I just got and X1 for a friend. the 64gb micro SDXC card is formatted exFAT and not recognized. windows will only allow it to format NTFS or exFAT for some reason, manual says i need FAT32 for the firmware update? plus need to use a card less than 32gb? i guess i will have to order a smaller card.
sorry not.
The only way I can think of is to not have the folder on the SD Card when you run the scan, then put it back on afterwards.
You'd have to go to Manual Scanning, put the folder in, and then not scan the card again. With Auto Scan, once you put the card back in, it will scan.
I have lots of music which I don't want to be scanned: for example audiobooks, podcasts and my electronic/techno playlists. That's why at the moment I'm using a Sansa with rockbox firmware installed and I can't upgrade my music player. I keep all the music that I don't need to be indexed in the database in a folder with a file named database.ignore inside. With this simple method I can put music on my player and keep autoupdating the database without messing anything up.
Any chance in implementing this feature in a future firmware update?
That's not really convenient if I frequently add music to my sd card.
