jj69
- Apr 18, 2003
What amp did you phiair it with?
WIth no amp. Line out to reference home system preamp.
then what reference home system pre-amp
I need to pair this X1 with an amp in the future!' so would prefer something thinner xD because thick DAP makes me feel like I am holding a C4 bomb hehe
I dont use rubber band for my rig xD
ok sorry for off topic post here but pls help me------------
all right ppl.i have decided to get either e17 or e07k but i want to ask a question.
will the dac part of these come in to play if i use these with aux??i mean headphone jack -headphone jack connection??or it will be bypassed and only player's dac will come into play??
and what will happen if i use the usb cable instead of aux for connecting amp with my portable source??
source is clip+
The Wolfson DACs(8740) on both is to bypass built-in sound card of PC/laptop when connected thru USB.(same port for charging) and you would connect an IEM/HP via the headphone out jack to listen PC/laptop audio.
The headphone out of any source(sansa/ipods etc) is fed into the aux input of E07K/E17 and you would connect an IEM/HP via the headphone out jack to listen to the source music,which means you will benefit only the amp portion of it.
thanks mate
and would there be a justifiable improvement in sound over clip+??
or i am better off with colorfly c3??
budget is only 100$
I was talking about the FiiO's stock thick flat rubber bands not the small conventional 3mm dia ones......which is specially designed to pair with sources.
Is your Clip+ RB'ed or stock UI? what's your IEM/HP to pair with your clip+?
its rockboxed
brainwavz m3 and vsonic gr07 mk2
