Interesting explanation. Thanks for taking the time to write that!
So that means e-stat amps are technically balanced by nature, aren't they? A 4-pin XLR jack has L+/L-/R+/R- just like a 5-pin STAX plug, but the STAX plug needs the additional pin (or two) for the high-voltage bias for the speaker diaphragm.
For the SRM-252S you mentioned that STAX skimped out on the power supply (I'm guessing the wall wart that comes in the package?) in order to make it more affordable. If it was supplied with a proper power supply like from a linear power supply, how would the performance differ from other solid state amplifiers (like the KGHVSS)?
A lot of the more expensive e-stat amps have a tube output stage, is this mainly for voltage gain as an alternative to resistors? If so, that sounds like a mighty expensive alternative. >.>
e-stat amps are balanced.
The SRM-252s output stage runs at 2mA, this limits the drive to power hungry phones like the SR009, the KGSSHV runs at about 10mA and the Blue Hawaii at 20-30mA
An internal inverter built into the SRM252 steps up the 12V to 550V with a max current output of 10mA
KGSSHV runs at 900-1000V and the Blue Hawaii at 800-900V
I have the 252S, replacing the wall wart with a fully regulated supply improves the performance when driving the SR-Lambda series(207,307,407,507) and the Sennheiser HE-60. It will drive the SR-009 if the volume is not turned up too high.
The linear amplifier part in the 252S is almost identical to the 323S except is current thru the stages is reduced. The 323S is like a simplified version of the KGSSHV.
The 252S does not use load resistors, it has an active current source like the 323S and KGSSHV, quite a nice design.
It also does not have any heatsinking so increasing the bias current will overheat the amp.
Replacing the cheap electrolytics in the 252 with high ripple Panasonics and Nichicon polymer caps will really wake it up.
Tubes are used to handle higher power at high voltages, the solid state silicon carbide high voltage transistors as just starting to become mainstream and I expect designs using these devices will start to show up in the commercial and DIY space in the coming years.
