DefQon
- Jan 14, 2011
Sort of.
The first one was bought over 2 years ago, back when I was just getting into this Head-Fi thing with only an AD700 to my name at the time. It was made clear that it had rebuilt drivers with 2.5 micron diaphragms, no mineral wool, and was generally not in stock condition...but that it still sounded good, and for $250 with an SRD-7/SB included, how could I say no? I already had a spare A/V receiver lying around to power the transformer box, so the amp barrier was not an issue.
Of course, I couldn't truly say I had an original, Normal-bias SR-Lambda knowing all the changes it underwent. The frame has seen better days, given how roughed-up it looks. The headband, while not obvious to me at the time 'til I got my hands on other Lambdas, is rather stretched-out, isn't as wide, and almost looks as if it was meant for a different arc assembly. The cable actually had a 5-pin Pro bias plug, though there's no way I'd dare risk killing the drivers by plugging it into a Pro bias outlet. (Given that the nameplates at the top of the cups are blank and don't have "PROFESSIONAL" or other text on them, I'm guessing that the original 6-pin cable was damaged somehow, and whoever repaired these things had to use a 5-pin replacement due to the relative lack of 6-pin Lambda cables.) And the pads...they were in such a terrible state that the prior owner actually cut strips of soft microfiber cloth and taped them to the contact areas of the earpads, just for comfort's sake!
Fair enough. I feel that you will definitely like the SR 5 or SR 5N Gold as the forward mids are sort of similar to the Lambdas just on the more fun and musical side.
