mutabor
- Nov 25, 2011
Well I don't have any iPhone 4S near me at all (none of my friends took the iP4 to 4S upgrade) so how do you think the 4 compare screen-wise? Or is the 4S and 4 the same in that regard?
It's a totally unfounded assumption. In lieu of evidence is a claim based on a single teardown by somebody who assumes it's an auth chip purely because he didn't recognize it.
The Thunderbolt connector is also chipped, but it's a multiplexer. After all, with nine pins at the Lightning end and four pins + shield at the USB end, it would make sense to put some logic in the connector, too. You can't simply run a wire from one pin to a totally different pin and expect things to work, the way you can with most analog and some simple digital connectors.
I trust AppleInsider only less than I trust Weekly World News.
To the 4S, or to the 5?
Well the 4 and 4S share exactly the same screen. Compared to the 5, they just look 'crisper' though after awhile, the colors look washed out versus the 5. My girlfriend took a picture of her house as her background, and is using it on both phones. On the 4, the grass just looks like paste compared to the richer greener one grass on the 5.
It's still going to take some getting used to...
4/4S to the 5. Hmm. Interesting. At least one of my iP4-toting friends is going to get a 5, so probably all of them are going to compare between each other. I'll just wait here nonchalantly.
The gamer one or the chronos one? The gamer one seems pretty good hardware wise.
This is a very good site with a lot of technical tests to see which performs better, and so on:
http://www.notebookcheck.net/Top-10-Desktop-Replacement-Laptops.17035.0.html
Thanks for the link. I meant the gamer one, yeah. For me it's between the Samsung or the Alienware....
I dunno, just not feeling the Asus so much.
Can the two guys who got the iP5 test if this is true? http://www.slashgear.com/your-8mp-iphone-5-may-only-give-you-4mp-photos-but-its-not-broken-21248848/
EDIT: oh wow, that article is getting a beating from the Nokia fans LOL. Also here's another one with picture comparisons. http://hiblue.com/2012/09/21/first-iphone-5-images-appear-online-pixel-oversampling-confirmed-offline-comparison-of-sensitivity/
The reviewer at the second link keeps saying that to use OIS the subject needs to "stay still" - that's not always true - it depends on the implementation of IS. For the low-cost IS that would be in a phone or P&S camera, it's probably true - but not with a good DSLR.
http://www.usa.canon.com/cusa/consumer/standard_display/Lens_Advantage_IS
So my Koss ESP / 10 arrived, and it looks to be in very good shape along with its matching transformer. This thing is a solid block of wood. Also low and behold, it has a Stax-type termination as standard. I've got the headphones charging, but there's a massive channel imbalance, and I'm hearing sound clearly from the left channel, whereas the right channel is extremely quiet (but audible if I lower the volume on the left side). I'm hoping this is one of those "needs to charge for an hour" things that pops up with vintage stats from time to time, otherwise it's either a cable issue or, worse, a driver issue.
From the side I can hear, these actually sound very nice, so I'm hoping this can be fixed.
This hobby is really annoying. I'm done buying vintage gear.
LOL. No, it's not. And no, you're not.But taking a little break is a good thing now and then...
You know, a "sorry to hear you were ripped off, MF" would have been appreciated.
