GearMe
- Feb 17, 2013
WOW
LOL. Totally funny reply. I have to agree.damn, nothing I like better than a vegetable jamming a toothbrush up my arse. Some seriously demented advertisers back then. And why is the celery supposed to french? So many levels of wrong going on here.
So, what's the verdict on these babies?
This is what I would get. Maybe a smaller size, but you get the Idea. I would wear it in my back though. Then I would use my phone as the remote to change songs with the Hiby or Fiio app through Bluetooth. I don't listen on the go anymore though.I have a question for DAP users. How do you wear/carry your DAP when you're listening? I'm just wondering if there's a better way than the quick release clip/mount system I've been using for years now. I got it from Amazon, it's no longer available but HERE is one just like it on Aliexpress. I can clip my dap to a pocket, belt, armband, etc. I'm curious what others are using.
Sweet! I did something too.....Some pics of the Scarlet Minis:
It's a good looking cable, too bad it's not usable for me.
Do you think the upgrade cable was worth it?
Thanks Brother! MusicTeck only has the Scarlets with the upgrade cable so it looks like I'm getting that one. I always buy from MusicTeck because he always gives me deals. Didn't on these but that's ok.Not in my opinion. It's an ok cable, not worth an extra $160.
I'm stoked for you bro. I look forward to hearing what you think about the Scarlets.
Now I'm looking at this cable.... it's on sale! Gets top reviews.
https://shop.musicteck.com/collecti...s/effect-audio-eros-s-1st-anniversary-edition
That is so pretty. So it's a stiff cable? Does it sound bad?You might be happy that the upgraded cable version was all that was available. I decided to try an old trick this morning on the upgrade cable. I took a hair dryer, warmed up the cable, and then I worked the cable for a bit. It loosened up a good bit and released the kinked memory spots as well. It's still not my favorite cable ever but it's way more usable now. It's what I'm listening with atm.
That Eros S is a good looking cable tho, sucks that it doesn't have the ConX options.
Wow, I'm totally off today.... starting a new job tomorrow so it's a bit stressful.
Anyway, I looked at the cable again and it has the Conx but not the Termx. I can use the extra Conx connectors that I'm getting with my other cable. I ordered it. We will see how it sounds!
