swbf2cheater
- Aug 14, 2009
Just one of my playlists are usually 12gb+ what a shame there is no support for micro sd
Worked brilliantly! I wonder what happened though..
Thanks again ClieOS!
I see some interests for this player. Here is an instruction how to re-load firmware, just in case. (A friendly reminder, They Don't Make Them Like They Used To; before you buy anything from foreign countries, please make sure you know what you get into.)
1. Download software
(3 download link options, first and second are direct link to teclast, third is my upload to mediafire.
first link, ftp://d:d@121.10.241.8:2121/teclast/mp3/Firmware/Xseries/X19series/TL-X19HD-V1.00-F340.rar
second link, ftp://d:d@58.248.4.28:2121/teclast/mp3/Firmware/Xseries/X19series/TL-X19HD-V1.00-F340.rar
third link, http://www.mediafire.com/?9dj8scgg7pkgwc4
2. Unzip file, double click the file named 'TL-X19HD.exe'; you will see an updater pop-up, message - 'searching', 'please connect device'.
3. Power off player.
4. Use a needle press reset button "R"
5. Press and hold 'E' button on the player while connecting it to your computer, until the updater finish 'initializing' - you can let you finger go now.
6. Click 'Start' on the updater. You will see blue-bar progress, wait until it finishes. (It's only a couple of minutes, but it feels like forever; walk away, before it drives you crazy.)
7. Done.
8. Power you player on, but if it does not work -- Use a needle press reset button "R"
9. Sometimes, you may need to do it the second time. (In this case, in the updater, check box 'format data area'.)
Final Note, it uses Sigmatel chip, it is not so easy to brick it. Good luck and having fun.
