Faust2D
- Apr 9, 2007
How much is it to have this done for Stax in Japan or by Yama in US?
Originally Posted by Faust2D /img/forum/go_quote.gif How much is it to have this done for Stax in Japan or by Yama in US? |
Originally Posted by edstrelow /img/forum/go_quote.gif I sent Yamasinc a broken low bias Sigma and they turned it into a Sigma/404 for about $500.00. This did not include the broken arc assemby (headband) that I also had to replace and which was extra. Obviously you would need a new estimate from them. Incidently the Sigma arc assembly is no longer avaialable but Yamasinc was able to use an older lambda band. |
Originally Posted by bjarnetv /img/forum/go_quote.gif i just replaced the cable on my sigma and it was quite a pain, as i didnt have any suitable crimps, and there were some kind of mysterious resistor on the old cable in the end, i just took the crimp and resistor part of the old cable and connected it to the new one. |
Originally Posted by spritzer /img/forum/go_quote.gif Ouch!!! Scrapping a new SR-404 for parts looks cheap compared to this... . |
Originally Posted by edstrelow /img/forum/go_quote.gif This was no bargain but it would be no cheaper to scrap a 404. The current US price for the 404 is $579.00. The 404 Japanese imports are about $450.00. Anyway Yamasinc did a good job for me. |
Originally Posted by spritzer /img/forum/go_quote.gif Very true but using a SR-404 as a donor phone will get you a very nice normal bias Lambda if the original Sigma drivers were still working. It should be clear though that these conversions aren't cheap... |
Originally Posted by edstrelow /img/forum/go_quote.gif I sent Yamasinc a broken low bias Sigma and they turned it into a Sigma/404 for about $500.00. This did not include the broken arc assemby (headband) that I also had to replace and which was extra. Obviously you would need a new estimate from them. Incidently the Sigma arc assembly is no longer available but Yamasinc was able to use an older lambda band. |
Originally Posted by John Buchanan /img/forum/go_quote.gif From memory, that is what I paid for my conversion also - worth every cent and more baby! |
Originally Posted by spritzer /img/forum/go_quote.gif The going rate for a Sigma Pro is around 800$ if you can find one and it doesn't even come close to the 404 drivers. Now I have this crazy idea to convert a Sigma Pro as a Lambda Signature in a SR-404 frame would be something very interesting indeed. |
Originally Posted by edstrelow /img/forum/go_quote.gif Does the Sigma pro use the Lambda Signature drivers? |
Originally Posted by John Buchanan /img/forum/go_quote.gif Birgir, do you mean swap the drivers between a 404 and a Sigma Pro? The resulting upgraded Lambda Signature should sound better (the 404 has better cabling and a better headband that allows tighter sealing around the ears). And you get the 404/Sigma Pro hybrid (mine was a Sigma that had 404 drivers, ear pads and cabling implanted - still has the original Sigma arc assembly however). Ed says the 404 hybrid is better than the Sigma Pro. |
Originally Posted by spritzer /img/forum/go_quote.gif Speaking off Lambda's, I'm going to send off one tomorrow for some woody experimentation which might be very interesting indeed... |
