Maverickmonk
- Nov 23, 2010
After finishing up a set of mine, I have a newfound apreciation for your work Bill. And yes, there are scorchemarks on most of my rings too, I just put them where they are unseen, I'm tricky like that. Endgrain is a PAIN to stain evenly, as the vertical grained portions and horizontle stained portions take stain at different rates, even after using a wood conditioner. Luckily these were single rings and you can't see half of the grain. I've found that the best way to run the wires is by drilling a hole for them, and then cutting in on the hole so you get an upside down U shape, this allows the drivers to be removed without soldering. I can't report on the sound changes, because I've only listened a little because my pads still turn my ears black. I need to find some retayne color fixative, but I can't come across it anywhere. The other solution is to just order bowls, which I know sound better but I have heard are uncomfortable. I'm also having trouble finding black metal screen, because all the screen I've found is either black nylon, or shiney/grey aluminum.
