Edit:
After going to sleep for an hour or so, woke up (bathroom) and had a thought, so I headed downstairs. I remembered when I opened up the right can for the 2nd time on the 325s, I had applied some small pieces of Dynamat to partially close off some of the holes I had opened up - to see how the sound would potentially change. I got out the heat gun and opened up right side again. I removed the Dynamat that I had set in place, so it was now just covering the magnet and the plastic side walls. I then assembled everything again. Let things cool down a bit. I then sampled some music - ahh ... it appears as if my 325s are back in business. They're sounding better - much better. I still need to A / B them along with the woody 225s and see where they stand - er, sound.
Original Post:
I think I need to start a new reality series for TV titled: "
When Headphone Mods Go Bad".
Today, I had some free time on my hands and made it out to buy some shrink tube, spade connectors and all that good stuff to work on some other projects. This evening, I then proceeded to work on my stock SR325 headphones. I proceeded with the following:
- Separated the driver assemblies from the aluminum cups by using a lil' bit of heat from the heat gun.
- Opened up the 10 holes on the back of the driver assemblies by removing the black veil.
- Removed the silken covers that protect the drivers on the side that faces your ears.
- Applied some Dynamat to the back of the driver magnet.
- Cleaned up some of the existing hot glue so it wouldn't get in the way of the new application of hot glue.
- Applied the hot glue and pushed the components back into place as good as I could.
- I realized I still had about 1/8" further to push the driver assembly into the aluminum cups.
- Applied a lil' bit more heat from the heat gun to the aluminum cups - and then pushed the plastic driver assemblies all the way into place.
Well, how did it all work out? Not so good - in fact, things sort of crashed and burned at this point. My right driver is vibrating with distortion as it tries to play music. The whole soundstage is off - even the left channel is just not good at this point. I suspect that the aluminum cups of the SR325 Grados are a whole different beast to work with - as opposed to the SR60, 80, 125 and 225. The aluminum obviously holds the heat for a longer period of time. Now, I'm wondering of that heat build-up and retention made a little "oven" and as things tried to cool down, my drivers were affected by the process?
At this point, I'm suffering mental pain from this apparent stupid mistake on my part. Ughh!!
