spurxiii
- May 18, 2013
Is the Pioneer SX-2900 considered at vintage amp? Its what I have but I'm not 100% sure if the headphone out is via built in resistors?
See if you can find a manual online, it should show whether or not it has it. That's what Steve Eddy told me
Originally Posted by SMG52 /img/forum/go_quote.gif
Flysweep....
It's certainly your call, but I am not sure how much the T amp you have will let you know what something like the Millenia will sound like (or the Odyssey amp for that matter). If you do some Googling about the Millenia, it's been used with ultra expensive speaker systems, and to good effect, and has also bettered many other well reviewed amps (T amps included) at or above it's price range. As Gary discovered and reported so well, different amps will have their particular characteristics. I think what might surprise people on Head-Fi is that if you look up some of the reviews of - for instance - the Emotiva amp, you will find similar 'sound performance' characteristics driving speakers as Gary found over his headphones. That is why when I researched the Millenia, I decided to try that amp in particular because of how well it did, and that was with speakers. With the ability to have an amp 'see' the load it prefers (using the resistors), it makes sense that its performance with headphones will mirror what people hear with speakers. Now if someone is of the camp that all amps sound the same, then end of discussion. I won't even attempt to go there (after almost 40 years into this audio hobby.....) But, all that being said, it's understandable that you might like to try out what you have in house. Hell, maybe you'll discover a hidden jewel and won't need to go any further!
best
@ Flysweep: With the resistor box, the Millenia is easy to control. Normal listening is between 8 and 10 o'clock on the dial, and the gain is pretty smooth. Interestingly, with the Odyssey, normal listening is between 7 and 8:30, but it is a very smooth gain, so pretty easy to control -- without any resistor box.
I agree with SMG that your T-amp and the Millenia will likely sound different -- just like the Emotiva doesn't sound like the Cyclops. At all. The only cost to try the Millenia is the return shipping, and it doesn't weigh that much. Not to be too much of a shill, but if you're already getting a resistor box from him, you might as well try the amp too...
Great points.. I wholly agree with you.. and I certainly do not reside in the camp that thinks all amps "sound the same".. so we won't have to walk down that rocky road.. LOL.
My goal in (initially) using a T-amp was to merely gather a baseline evaluation of what the HD800 might sound like when driven off a speaker amp.. and how that "speaker amp" SQ compares to the "headphone amp" SQ I'm currently getting with the HD800 (from the Vio stack & the BH Crack). This exercise wasn't intended to determine if a "cheap" speaker amp (T-amp) would sound just as good as a more expensive speaker amp (Millenia). I'm quite confident the Millenia is head & shoulders better than my cheap T-amp. I guess the one thing that might help (me) is if Gary was able to compare the LCD-3's SQ off a speaker amp vs very good headphone amp.. but something tells me he might've done this, already.. so maybe I need to go digging around in this thread.
Excellent.. so w/ the Millenia at 8pm, the gain is suitable for low volume, quiet/"background-level" listening.. and there isn't any channel imbalance?
I am really tempted to just get the Millenia.. especially w/ the trial/evaluation period Jan offers. The SQ is certainly the biggest draw for me w/ the Millenia.. but the size of the unit is just as valuable to me.
Gary.. one more questions in regards to the Millenia, if you don't mind: you mentioned it had a warm-ish presentation.. did you find that type of sound to come at the expense of the treble? More specifically, did the treble quality remain extended, detailed, present, and articulate?
I actually have no problems whatsoever with the (stock) HD800's treble quantity.. I quite like it really.. so my only concern with the Millenia is it potentially "rolling" off the treble somewhat prematurely.
In my view the Millenia whups the Mjolnir and the Soloist, the two <$1K speaker amps that most folks around here are into these days. It ain't even close. My reviews of all three are in this thread (just search for my posts with those words in them), though the summary I provided just above also provides a snapshot of what I think of these competitors.
There is no channel imbalance at normal listening levels (~70 dBs or so on my phone's sound meter app) with the resistor box.
There is no treble roll off. It is extended, detailed, full-bodied -- as in you hear real cymbal sound, not a bunch of hissing snakes. But just as a disclaimer, I did not like the HD-800 when I demo'ed it last year with my Adcom pre-amp and the Burson HA-160. Both amps of those amps have rolled off treble and I still thought the HD800 was too sizzly, so my view of proper treble reproduction is probably different than yours. But if you want what I believe is accurate treble sound and energy level without the harshness, I think the Millenia gives it to you, particularly with Jan's stock resistors. As always, however, I urge you to try it for yourself.
Originally Posted by Gary in MD /img/forum/go_quote.gif
...To be honest, though, I really want you to try it because I am a bit intrigued by what the HD800-Millenia combination would sound like. To me, the Senns were too focused on big sound stage and treble, and didn't have enough body in the mid-range and bass. The Millenia might provide exactly what the HD800 needs. Or not. Only one way to find out for sure...
Looks like there is a resistor in series, 330 ohms.
Gary,
Not to hijack this thread, but I've had an interest in possibly checking out the LCD-2s sometime. I assume from your experience with the 3s, they would also work well with the Millenia?
The Khartago received quite a rave review in Absolute Sound a couple years back. Not surprised you liked the Cyclops (although I haven't heard any of the Odyssey amps myself).
Your experience in audio (40 years) sounds like it parallels mine!
Excellent.. that was quite helpful. I've heard from many people (who's ears I trust) that the HA-160 is pretty underwhelming with the HD800 too, so you're not alone in that assessment.
I understand & agree with your sentiments about the HD800 being "soundstage focused" & lacking body in the midrange.. that lack of body is what gives it that 'silky' quality, IMO.. but yeah, it can definitely feel like it lacks weight.. and a big part of that is what's upstream of it.
I've asked Jan to add the Millenia to my "resistor box" order, so consider your wish fulfilled.. thanks for your help & I will report back on how the HD800/Millenia combo sounds.
