Cause your rig is bright.
Oh Schiit! The little buggers escaped!!!!!
Hmm they looks like the Mills I used (glossy metal), but then I did see a picture of mills in a rougher enclosure. Kinda bug me at first that I can't find the Mills that look exactly like this picture below - but they are the same I think, just different enclosure?
If this box is paired with the HE-6 50ohms, the impedance seen by the amp would be 1.9ohms.
These resistors look different than the Mills I use.
Did you solder it on or are they clamped into the speaker terminals?
That's not soldered. That's a 5-way binding post speaker terminals, the hp is using banana plugs and the resistors are tightened by the screw type speaker terminals.
That is Grokit's amp. I did the same to mine - old picture but you get the gist.
Most speaker binding posts have a small hole, right below the screw/cap - for people who uses bare wire instead of banana/spade. I just put the leg of the resistor in and screw on - tight and snug.
Was just wondering if a slight knock on the amp might loosen the clamp on the resistors...just a worry wart I am.
Try the 4 Ohms.
