ALRAINBOW
- Oct 5, 2012
Yes thanks . It's just barely warm now. I think Bruno and them were right it's not hot till your fingered sticks to it. LOL.
Just finished my test with the resistor box using the TBI Millenia and LCD3. I bought about 50 resistors to test all possible configurations. With the optimal resistor box(R2 = 6, R3 = 2.2) the hiss is completely gone but the dynamics of the music are missing, the high notes are a bit silent, soundstage a bit smaller, basically everything is toned down. Using just attenuation so R1 = 147(to match the attenuation of the resistor box) is sound much more better. From initial listening tests it sound 95% like using the LCD3 directly from the taps but without the hiss. Currently I am using R1 for 100ohms and I think will be my setup of a while.
I am curious why adding two resistor changes the sound so much as opposed to just one.
My concern is if the Millenia can handle this long therm since it's effectively sees 150ohm speakers. Also I had some initial worries about the damping factor but it looks like it does not affect planar magnetic drivers as much as I thought.
@potterma perhaps you are onto something here in regards to the mechanical connection of the resistors. The losses we are experiencing may in fact be due to the leads of the resistors themselves. I may have a possible solution for that. Can you or someone else using the resistor network snip off the leads close as possible to resistor and solder on a 20awg solid core fly lead and see if listening impressions improve? Most resistor leads are quite thin and we may be running into a limiting/loss effect due to that. I would do it myself, but I only have the HE-adapter box and I really don't feel like hacking it up right now lol.
Awwww come on.... Where's your spirit of adventure?
I would think that the resistor-resistor connection and the resistor type would have more effect than the resistor leads. I tried metal film power resistors and did not like them at all. Killed the hf dynamics, for some reason.
I might have to make some carbon comp resistors and give them a try. Can't stomach paying for 'em, though :choke: :cough:
Lol, yeah I agree on both adventure and effect (lack of) of resistor leads, but its a cheap non-destructive option. Hehe! Yeah those things are quite expensive for what is effectively a pencil lead
Not just "effectively a pencil lead". EXACTLY a pencil lead...
i have figured out my resister heat problem . I just put two 20 ohms in parralell so all is better now. with the amp i am using now i need the attenuation and proper loading of amp output. with the he6 its fine with no attenuation but there is a slight low hiss and with the HD800 the his is there but attenuation is a must to get to 1/3 of the volume level and not be very loud. thanks so much .
al d
