- Sep 25, 2010
Soundware - any idea when the 'only power on by USB cable bug' will be fixed as its getting very frustating for me and I might end up selling the M1 if its not fixed. thanks
Nik is it more than you enjoyed it with the Zen? I'm quite curious about the LZ.
Who compared with QLS QA360??
To Soundaware:
# of bugs is flagrant: periodical double screen, permanent issue with power off and unlimited battery consumption, self settings changing, all above end etc.
What was the reason to issue a product with such raw software? Why your engineers can't take the interface from other products like fiio for example?
I was thinking about soundaware d200 as my next purchase to home system, but not sure anymore...very disapointed
Stay updated on Soundaware at their sponsor profile on Head-Fi.
I have attached a double screen issue.
Double Screen? Could you help to take photos for us to check?
D200 is our desktop streaming transform system, which is more stable than M1.
M1 is our first DAP, really not good in firmaware. Our engineers are working in the development for it. Actually, we are also very anxious, waiting the development.
@sonickarma: Do you have the following PowerOff settings?
• Auto PowerOff = Never
• Smart PowerOff = 10, 20, or 30 minutes
• Power Key Setting = Long Press Sleep
With those settings, Esther should never fully shut down unless you fully deplete the battery. It will just sleep instead. So you'll need to make sure you keep Esther's battery topped-off. I fully understand that this "fix" isn't ideal and am also hoping Soundaware provides a better solution soon because sleep still slowly depletes the battery.
