SOUNDAWARE M1(PRO) Portable Player with Proprietary FPGA Architecture
Aug 20, 2018 at 8:53 AM Post #1,081 of 1,094
Having Just bought an Aune M2 Pro, and owning already a Mojo, I am wondering about getting a "complementary" DaP and maybe sell the Mojo.. in that regard do you still think this DAP Will perform close to Mojo? M2 is effortless and detailed, but I am looking for the same engagement I feel with Mojo.. hybrid iems (iBasso IT04), so impedance I believe should not impair that much....cheers
Aug 20, 2018 at 9:20 PM Post #1,082 of 1,094
Sorry this is Soundaware M1pro thread, you need to find Aune‘.
:sweat_smile:
Soundaware Stay updated on Soundaware at their sponsor profile on Head-Fi.
https://www.facebook.com/Soundaware-Audio-CoLtd-140035019979865/ https://www.us.soundaware.net/ Soundaware Official market@soundaware.net
Aug 21, 2018 at 2:14 AM Post #1,083 of 1,094
Aug 22, 2018 at 3:17 AM Post #1,084 of 1,094
The idea is to get ALSO an M1 PRO! :wink:
I see. Then I would recommend our new flagship DAP, and coincidently it is also called M2pro because it is the upgrade product of M1pro.
Detailed description will be released very soon.
Pls stay tuned.
Oct 1, 2018 at 2:58 PM Post #1,085 of 1,094
I have updated my M1 Vitality to 085 firmware.
1. Not work Smart PowerOff: At any settings always full power off. For power on I must connect to power adapter.
2. Strange but from power settings disappear Power Key option. By this event I can't send my player to Sleep Mode by pressing power button.
Back to 076 and resolve this problem.
This my own problem or another users have same issues?
Oct 6, 2018 at 11:01 PM Post #1,086 of 1,094
Firmware 085 does cancel the smart power off.
So it's better to stay with 076.
If you want to use 085, the only way is to upgrade your M1 to femto version.
Thanks
Oct 8, 2018 at 2:00 AM Post #1,088 of 1,094
What improvements are there with 0.85?
Some optimization on menu, file management, volume control and DSD library.
Debug some unusual crash situation etc.
Oct 8, 2018 at 9:39 AM Post #1,089 of 1,094
soundaware thanks for answer.
Upgrade it means change to new PCB? As described here:
Oct 9, 2018 at 10:02 PM Post #1,090 of 1,094
Oct 12, 2018 at 4:11 PM Post #1,091 of 1,094
Oct 25, 2018 at 3:01 AM Post #1,092 of 1,094
Hi, is it true with 085 update the "lock" button on the side becomes basically useless? I mean the function associated with it is no longer working?
If yes, why is this?
Thanks
Oct 28, 2018 at 10:27 PM Post #1,093 of 1,094
Thanks
Yes, we cancelled the lock button on the side.
But you can short press power button to lock the screen, like mobile phones.
It is more straightaway.
Thanks
