Passion for sound and Darko Audio are good tooSo do I, but even more, I like that guy "Passion for Sound" from Australia.
Cheers!
OK...I like Steve Guttenberg too
Sony Z1R....listening impressions only
At the moment the lowest price seems to be on Sony UK website. On Amazon and other websites are more expensive.
fidgeraldo
Good reminder. I like Darko, too!Darko Audio are good too
Also, what I like about these reviewers is their positive energy, which seems honest to me.
Enjoy!
Cheers!
I now own the ZMF atrium and Verite, DCA expanse, and Sony Z1R. I can say without a doubt the most comfortable the are the Sonys. Its like pillows.
How is the expanse vs Z1R?I now own the ZMF atrium and Verite, DCA expanse, and Sony Z1R. I can say without a doubt the most comfortable the are the Sonys. Its like pillows.
gerelmx1986
fidgeraldo
You are straightforward But, yes...not the best lookLooks ugly.
I am not much into cables, and if they are very different from one another (I spend a certain amount on better cables, hmm, they also look better with a higher price)... I will eventually buy some Forza cables for Z1R...only for the good looks
If not, I like these, which I got with Z1R; I purchased a 4.4 mm to XLR extender, and my ears like it a lot.
Cheers!
- Jun 22, 2015
What makes the DHC Ultrashort worth the money is that they are designed to be neutral and use the highest quality components, wire and solder. With cheaper adapters who knows what they use or how it's built.You are straightforward But, yes...not the best look
Cheers!
gerelmx1986
I know... but as long it sounds transparent and lets me use my Z1R cable without having to order yet anither cable, i dont care how it looksLooks ugly.
I think its very hard to compare these as these sound completely different.Everyone is talking about Dan Clark E3 closed back headphones. So hopefully someone will and can compare both.
Still trying to decide between the Z1R and D,9200 as they are ready to drive and E3 is not. They say.
The E3 sound surprisingly... weird. While the Z1R sounds very wide and more like a live concert, the E3 sounds surprisingly similar to a typical chinese Headphone. A lot of songs will hurt your ears, especially with strong female vocals and the bass sounds very lackluster.
I can listen to the MDR-Z1R without EQ but imho this is not possible with the E3. It reminded me a bit (its still different though) of the Moondrop VENUS.
If you like the Blessing 3, Moondrop VENUS and similar Earphone/Headphone, you'll like the E3 but that is just completely different to the MDR-Z1R. They are basically a cheaper/worse version of the Stealth and the Stealth already sounds strange to begin with
I haven't done a direct comparison so this is all from memory but the biggest differences I'd say are the middle bass and mid range. The Sony are more V shaped with mid scoop out which makes certain sounds more distant. It does give things a cathedral like sense of space but it's not as accurate. The treble has more spikes on the Sony which makes certain things a touch sibilant but it's not painful.
The expanse are more power hungry but more portable which is a little funny to me. They can collapse down to a much more portable size but you'll need a portable amp to drive them.
Overall I would say the Expanse are better technical headphones but the Sony are half the price and by far more comfortable. Both are well made and feel premium though I think the Sony seem nicer subjectively.
gerelmx1986
I laced an order for a new Kavri Grand for my Z1R in 3.5m long with rhodium plugs and same rhodium for 4.4mm
Why so long? Are you going to watch TV with it?I laced an order for a new Kavri Grand for my Z1R in 3.5m long with rhodium plugs and same rhodium for 4.4mm
