Sony WF-1000XM4 Impressions Thread
Mar 13, 2023 at 6:15 AM Post #2,821 of 3,007
Looking for some suggestions for XL tips for WF-1000XM4. Large Sony OEM tips are too small. I am currently using large Comply TruGrip Pro memory foam tips.. They barely seal and leak when laying down/reclining. Hoping to find a slightly larger foam tip to get the best out of the XM4. There seems to be a bit of wiggle-room in the Sony charging case so slightly larger tips than the Comply should work.
I would appreciate any suggestions from experience Head-Fiers.
I use these tips,, These beat the sony tips by a mile, but they dont last very long as they are much softer... https://www.amazon.co.uk/dp/B09L7D1Z4V?linkCode=ogi&th=1&psc=1&tag=superofcom09-21
Mar 13, 2023 at 11:14 AM Post #2,822 of 3,007
Mar 13, 2023 at 9:18 PM Post #2,823 of 3,007
Just listed a very nice pair of XM4 for sale in the listings forum...
Mar 15, 2023 at 12:13 PM Post #2,824 of 3,007
Mar 15, 2023 at 12:27 PM Post #2,825 of 3,007
Mar 17, 2023 at 12:08 PM Post #2,828 of 3,007
Mar 18, 2023 at 9:31 AM Post #2,829 of 3,007
I recommend this EQ for the XM4 (I'm using the 2.0.0 firmware):
Clear Bass
400
1k
2.5k
6.3k
16k
+1
+2
+6
+3
+3
+6
Mar 21, 2023 at 3:37 PM Post #2,830 of 3,007
I'm getting audio dropouts on the left channel after updating to the new firmware for multi-point. Is there a fix for this?
Mar 21, 2023 at 10:46 PM Post #2,831 of 3,007
Ive been looking at the "Sony LinkBuds S" and review say they are pretty much identical to the xm4s accept there slightly smaller, dont have wireless charging and slightly less bassy but hardly noticeable.. So do anyone own both these buds and if so can you tell any difference in sound quality,, as Im thinking of getting these and selling my xm4s just because the LinikBuds S are smaller and might fit better in my ears?
Mar 21, 2023 at 11:17 PM Post #2,832 of 3,007
I have both and there is a difference in sound quality. I'm not at all good at describing them - however, I did find a video that does a good job at describing what I cannot at 11:45.
Fit and comfort, LBS for the win. SQ wise, LBS sounds a little brighter and less dark than the M4 stock sound.
Mar 22, 2023 at 12:51 AM Post #2,833 of 3,007
One of the guys on the tws thread went from the linkbud S to the xm4 and found the xm4 a bit darker (fixable with eq) but better detailed (and way better ANC) iirc.
Mar 22, 2023 at 3:55 AM Post #2,834 of 3,007
I’ve got both. I do find the XM4 to be the better but I could easily live with just the S.
I use the XM4 for music on the go while I use the S as sleeping buds with audio books as the smaller size means I can lay on my side on the pillow with no discomfort, something I cant with the XM4.
You might want to wait for the upcoming XM5 which is rumored to be more like the S in size
Mar 23, 2023 at 5:11 AM Post #2,835 of 3,007
Anybody compare wf1000mx4 with Sony EX800ST or MH1C or KEF M200 ? How they compare in sound signature ?
