Sony WF-1000XM4 Impressions Thread
Mar 3, 2023 at 3:38 PM Post #2,806 of 3,004
Playing a 44.1 kHz FLAC.
Tidal playing in Exclusive mode - as the MQA file unfolds to 88.2 kHz, it's using this sample rate too when sending the data to the headphones, and it switches to 44.1/48/96 kHz too depending on the file.
Yes it works fine
Mar 5, 2023 at 7:49 AM Post #2,808 of 3,004
After upgrade to 2.0.0 my right earphone progressed fast discharging even faster, in 40 minutes maximum. Left is working as before, around 4-5 hours.
Also, battery charge indicator in application stopped to work (it shows 100% for both buds and case).
Does anyone has similar symptoms?
Only change for me is that ldac consumes battery about 50% faster than aac now that I have mine connected to both A55 and iPhone. In this config I get about 5-6 hours with eq and anc active
Mar 5, 2023 at 8:33 AM Post #2,810 of 3,004
And indications of battery charges properly presented in app?
Yes. With just aac connected to iPhone they consumed about 10% per hour, with dual connection to A55 and iPhone and playing music over ldac they consume 16-17% per hour
Mar 5, 2023 at 3:04 PM Post #2,812 of 3,004
Mar 5, 2023 at 3:47 PM Post #2,814 of 3,004
MDR Proxy is tool for downgrade firmware or flash fw from other regions. It is not required if everything went smoothly:)
Yes I know what it is but the link you referenced said that the procedure was only required for MDR users so i assumed that it was only MDR users who will have the problem in the firstbplace
Mar 12, 2023 at 12:38 PM Post #2,817 of 3,004
Looking for some suggestions for XL tips for WF-1000XM4. Large Sony OEM tips are too small. I am currently using large Comply TruGrip Pro memory foam tips.. They barely seal and leak when laying down/reclining. Hoping to find a slightly larger foam tip to get the best out of the XM4. There seems to be a bit of wiggle-room in the Sony charging case so slightly larger tips than the Comply should work.
I would appreciate any suggestions from experience Head-Fiers.
Mar 12, 2023 at 12:48 PM Post #2,818 of 3,004
I’m using Final Audio E LL as all Sony tips are too small. Use them both on Z1R and XM4
Mar 12, 2023 at 9:25 PM Post #2,819 of 3,004
Thanks! I placed an order through Amazon. Any recommendations for memory foam tips?
Mar 12, 2023 at 10:07 PM Post #2,820 of 3,004
Haven’t used any of them for many years so can’t help, but when I did I used the Comply with the build in wax guard, this was on Etymotics
