Cecala
- Mar 15, 2007
Have you tried Poweramp?
The problem is the stock player does not handle Ape. So ditto for anyone using Poweramp?
this is going to sound really stupid... ensure the buttons on the side & base are in correct positions.
Sinon... you have to download the drivers to your PC and install on PHA-2... I had same problem.
Do not install from Sony-Japan unless you have Japanese language-pack installed for Windows, can cause periodic blue-screen shutdowns... Use the link below for a safe installation, hth.
Download:- http://www.sony-asia.com/support/download/576681
PHA-2 thread:- http://www.head-fi.org/t/680208/sonys-dsd-capable-pha-2-portable-headphone-amp-dac/285
Respectfully, .Ape is lossless, is it not? Is there a reason why you cannot simply transcode to .flac? (I know it's a bit of a hassle, but...)
Already did yo xD
Thanks OK-Guy (your comment is not stupid at all, frequently the most obvious answer/s solve/s problems). Nonetheless, I made sure all buttons were at the correct positions; when I tested all possible connection ports ie. Audio In, Digital (Apple products) and USB (PC). The only connection/port is not working is still the "hi-res audio" connection between the ZX1>PHA-2.
Thanks Rudi for showing me OK-Guy previous post; to make sure, I have re-installed from above mentioned link, unfortunately, it is still not working . Nevertheless, I called Sony technical support to help me out here, hopefully we can sort it out without me sending the PHA-2 back to Japan.
Cheers
SimonT
Does this player have English menu? I'm eyeing one from Japan.
