kms108
- Jan 27, 2012
Have a look at ZX2 and ALO CDM combine. :0)
Using MWC-NWH10 to connect and play DSD64 files.
but i am having problem as the DAC is picking it as 44 if i use Onkyo HF player.
If i use the stock player, it is on DAC shows 88 (also not right but at least higher rate).
Saw this on a page earlier.
"Sorry Beemarman, but I was totally mistaken about using the Onkyo app on my Sony! I just tried it tonight and mine does the same thing as yours. I read the the info on the app in the Google store, and noticed a comment that said: Note: Audio with a sampling rate exceeding 88.2 kHz output via the headphone connection, AOS connection, digital connections via OTG cable (free version only) is downsampled to 44.1 kHz. It appears that even though I have the hd version (ie., purchased and unlocked), it is down sampling everything over 88khz to 44.1khz., not to mention the upsampling function for taking 44.1khz and higher up to 192khz is not functional either. I am using the WMC-NWH10 digital usb cable out of the Sony, BTW. As you mentioned, I plugged my iphone in and everything worked as expected. Sorry for the earlier misinformation."
There is a Onkyo player unlocker (at a cost) which should resolve the limitation on the BOLD statement.
But i still cannot get it to do go higher sampling rate.
Any advice on this?
I'm not too sure what the actual problem is as I don't. Use a external DAC, but have you tried Hiby music, I use this on my smartphone, but on the ZX2, the hardware buttons don't work.
