T.R.A.N.C.E.
- Mar 24, 2010
I know but for the money I want a blazing interface. I have an iPhone 6 for music now - it should at least match that interface speed for being over $1000. Especially if the OS has less to do. And why don't we have retina level displays?
That's unreasonable thinking. The iphone 6 is RRP $1000. The most expensive components in this are the screen, cpu and aluminium body and it cost a bloody grand for that.
Now lets look at the Sony ZX2, RRP $1120. ZX2 aluminum copper chassis (much more expensive and complex than the iphones chassis), the 128gb of inbuilt memory (worth $100), Sony has to design a high end audio circuit in addition to the regular design of of the main CPU PCB (iphone only needs this). ZX2 circuit boards for audio and CPU are separate, requiring two different manufacturing batches, iphone only needs a tiny PCB with everything jam packed onto it. ZX2 uses many exotic hardware components (pcb, caps, smds, super cap, MELFs etc) in the audio circuit, which believe it or not will cost more than the standard stuff found in the iphone. On top of all this the mid range screen and CPU still cost a decent amount. Also remember Sony had to design and produce the S Master HX chip, while iphone is made up from off the shelf 3rd party made chips.
Now you think that Sony could chuck in a very expensive screen and cpu while still having a similar price to the iphone?
They both have similar RRP, so you can't expect Sony to do what you are asking, they traded off the expensive high end screen and cpu, for a higher end chassis, more memory and most expensive: the high end audio circuit design and production.
