- Mar 20, 2013
inky black background
That's the clear sign that it does what it's supposed to
Enjoy!
Stay updated on iFi audio at their sponsor profile on Head-Fi.
I think someone wanted to hear my comparison between my SU-1 to the DI-20 that I got, here you go. The difference is there and you can do it but may not be worth $600. Time will tell if it improves even more yet with an external clock if I go that route.
No one can answer that without knowing the DAC because it is entirely implementation dependant.Hi, does anyone know if the Singxer SU2 will passthrough mqa to my dac. TIA.
Yeah, only decodes over USB =/Thanks, its a topping D90 mqa
But almost all DAC only decode MQA over USB. The decode happens after USB chip.
Singxer SDA-2 does not work for me when USB is off, as stated in the instructions.Sadly the singxer won't accept a usb cable with 5v pin blocked.
Yes - I am using AES, Coax, and I2S simultaneously.Yup, all outputs are active at the same time
