Baten
- Sep 13, 2012
I think plug and play SU-6 is also worth considering
In my case, the simple 5V mod made a huge difference, powering with an Uptone LPS1 or standard LPS fed with mains regenerator (and lately I find extra LT3045 regulation seems to stabilize things a bit more). Without the mod, the SU-1 was un-listenable (3 weeks break in), even with a mains power regenerator - the SU-1 here was very pronounced and grainy in the highs.
If the Kitstune mod is close to the cost of a U-16, you may want to consider a U-16 and a 5V Su-1 and see which you prefer (if you are lucky enough to get the U16 working ..jejejejeje). The 5v mod requires an external 5v power supply and DC cable. The cheapest I could recommend would be this (I think some folks use battery packs also..)
https://www.ebay.com/itm/15W-Linear...330448?hash=item41e5167cd0:g:cfcAAOSwwitejE7B
I have had 3 U16's, a modded U12, a few other DDC's, and have what I think is the first sold SU-1 from Kitstune.
I think the 5V mod SU-1 can match very well with warmer DAC's. I am using it now with my R2R11, but quite an elaborate computer setup feeding it.
U16 can be amazing when working well, especially with an external 10M clock.
I suggest to try something other than the laptop, because a lack of detail / bass definition to me is not a typical SU-1 trait (but I have always used i2s...).
Thanks for the info about the CD transport, some years ago I had a Jolida player that was excellent as a transport (and was better than my laptop until I loaded Windows Server core and AO)... but the convenience of computer audio is amazing - and it's kind of fun being in the thick of this new computer audio technology stuff...
Of course expect this is dependent on entire chain, as I have not had that experience at all with my gear. I also prefer the I2S interface as my main reason for using a DDC, perhaps with USB results would have been less favorable for me but I am quite pleased with SU-1.In my case, the simple 5V mod made a huge difference, powering with an Uptone LPS1 or standard LPS fed with mains regenerator (and lately I find extra LT3045 regulation seems to stabilize things a bit more). Without the mod, the SU-1 was un-listenable (3 weeks break in), even with a mains power regenerator - the SU-1 here was very pronounced and grainy in the highs.
Interesting, thanks. For me I already have what is in all likelihood the best cost/performance ratio DC LPS called ISO-PS from Ciunas Audio that provides DC power directly from a supercapacitor which is said to be audibly better than through a voltage regulator. I also have one of the early first-gen SU-1's so I wonder if the DC mod with this decent LPS would likely match the U16. I have a possible lead on a bug-free U16 used.In my case, the simple 5V mod made a huge difference, powering with an Uptone LPS1 or standard LPS fed with mains regenerator (and lately I find extra LT3045 regulation seems to stabilize things a bit more). Without the mod, the SU-1 was un-listenable (3 weeks break in), even with a mains power regenerator - the SU-1 here was very pronounced and grainy in the highs.
Yep - the Cuinas Audio guy has been doing power supply and DAC stuff since I remember starting in computer audio - I would trust that is a great power supply. I was going to order a Cuinas but already have a few LPS-1's and a LPS1.2 so put that Cuinas on hold until the world economy stabilizes a bit...Interesting, thanks. For me I already have what is in all likelihood the best cost/performance ratio DC LPS called ISO-PS from Ciunas Audio that provides DC power directly from a supercapacitor which is said to be audibly better than through a voltage regulator. I also have one of the early first-gen SU-1's so I wonder if the DC mod with this decent LPS would likely match the U16. I have a possible lead on a bug-free U16 used.
Wow, why did you have three U16's were they all buggy? And you said the 5V mod can match very well with warmer DAC - does this mean it's a bright signature?
The seller also has an external 10M clock. Would you mind to say what kind of improvement or difference this makes?
When I have time I'll also look into your idea of Windows Server Core and AO. Does this require a change of operating system and any costs? Thanks!
Any idea how to use xmos control software on windows 10 with the U12? I happen to only be able to use the oldest drivers without the controller.
PS: driver 4.13 works fine but sadly not the xmos controller I'm used to such as controlling latency and buffer.
Instead if investing in pricy supercap PSU, I'd personally try to sell the SU-1 and invest in SU-6 which is also powered by supercapacitor supply.Being new to the SU1, picked a used on up recently after killing the USB input on the DAC, I am reading through this thread (halfway through) with interest.
I have the magna modded version with some new Caps and voltage regulator upgrade, I am using an INtel NUC on an ATL LPS running Daphile, connected via a network switch running CAT 8.1 cables with a JCat USB rev 1-1 in the make (well the adapter board to connect it is underway) now running SPDIF to my Metrum Amethyst. I wonder if switching to a Ciunas PSU for the SU1 makes enough of a difference, does anyone care to comment?
(my biggest question is if the SU would benefit more from plenty smaller faster caps in parallel)
(am using a total of 4 13" high efficiency speakers that are quite revealing)
From an inside source I've gotten word that Ciunas Audio may be going out of business. Hopefully temporarily anyway but their website is already shut down. While not going to discuss particulars here, it has to do with issues that occur when opening it. If you still want one, PM me and I'll provide you with the email for the owner so maybe you can work something out with him to build you one while still possible. Build issues aside, they are bar-none the best sounding performance for the price as far as a DC LPS goes AFAIK.150 Euro for the Ciunas supercap PSU, versus 600 for the SU6, let's say I can get 200 for the SU1...that still leaves a largish gap. Is the SU6 THAT much better?
As a satisfied SU-1 user but of course always interested in what may represent next level of improvement, I look forward to your comparative impressions DL. One thing that interests me with SU-1 is the supercaps power supply, perhaps diminishing need for an external LPS. Do you use an external power supply with your SU-1 / plan to with the DI-20?I'm getting my DI-20 (98/90M version) next week and can compare to the SU-1.
I don't use an LPS with the SU-1 but was considering it until I heard what a bit improvement the DI-20 is supposed to be even over the upgraded SU-1 or SU-6. Don't quote me on this but it appears that the DI-20 has an internal design separating the power filtering from the rest of the circuit, maybe even having an internal LPS. I'm also connecting mine to an AC power conditioner so shouldn't need an LPS, except for the DC LPS for my DAC. I encourage you to join this thread for it, and there's a few other cool things there now too.As a satisfied SU-1 user but of course always interested in what may represent next level of improvement, I look forward to your comparative impressions DL. One thing that interests me with SU-1 is the supercaps power supply, perhaps diminishing need for an external LPS. Do you use an external power supply with your SU-1 / plan to with the DI-20?
