M Coupe
- Dec 20, 2012
With both my 535 LTD and 846, there is a bit of fear with removing the tips the first time. The same tips do get easier to install and remove with a couple of removals.
Also, my method is the same as Someguydude. Pinch with fingernails around the hard plastic inner area and firmly remove. You won't break anything. I felt like it took 20% more power to remove than was safe the first couple of times. Now, I just pop them off...no freezer or any other surgical procedure.
Now put your back into it and take those tips off
