jlbrach
- Jun 4, 2005
I also love my 846 with my AK 120 Titan using WAV files....simply wonderful
Purely objectively the 3ohm output causes a 2.5dB variance in frequency response compared to 0ohm. Essentially making the resulting curve sound like you were using the filter one below what you are. White becomes blue, blue becomes black, black becomes mud
Which I actually find really useful since on the road the extra bottom end helps drown out low frequency background noise like road noise or engines while at home I don't need the boost.
Yeap, I have similar findings subjectively. 0 or 1 ohm sound great with SE 846, anything higher I always end up adding 1 or 2db up on the treble to compensate. So for example, in my ZX1, I need to add +2/3 on 16K and +1 on 6K on ZX1 in order to have the same treble energy on my M8 (1ohm) and Dacport 1(ohm) with no EQ at all. But then the plus point is the bass gets slightly heavier on zx1 (which sound good although not as tight). When I play with the imp switch on M8, the higher setting of 11 ohm sounded veil, bassy (muddy), slightly U shape vocal and dark than the 1 ohm level where the vocal is louder, cleaner and treble more airier and bass tighter Some people prefer 11ohm and some 1 ohm. so this is a very subjective experience but the point here is the impedance plays a very crucial role in the final SQ, so diff impedance for diff phones produce a totally diff sound quality. my 2 cents!
If I'm not mistaken the rule of thumb is a ratio of 8/1, headphone/amp impedance
Yes sir, output impedance is about the only thing that significantly affects sound quality besides source material and transducers.
These are not dynamic drivers. The rules of full sized speakers don't apply. The 8:1 rule goes out the window when dealing with devices that get their response modified by using inline resistance. Using Etymotic as an example, their 100ohm ER-4S is 9ohm earphone and 91ohm inline impedance, ie effectively as if the amp had a 91ohm output impedance given it a 1:10 ratio and yet no control loss.
I love the combination of AK120 plus my SE846's
Yes sir. Very nice combination.
I'd disagree that the black will thus sound like "mud". The black should actually sound "neutral" (following the logic). In fact, it would be more neutral due to it not having the same bass enhancement as the other two filters.
HeadRoom reran the measurement on a more recent batch and the graphs now show the black filter as expected and not borked like the first one they measured. Which is to say acoustic dampeners doing what they do.
Perhaps my expectations are a little too high, but I find that it wasn't worth the upgrade from my SE535 instead at this price.
